1978 cutlass supreme paint codes
Old Mar 15, 2013 | 10:15 AM
cutlassrichard's Avatar
I Was Wondering If Anybody Knows The Paint Code For My Cutlass It's Gray with a black vinyl top and factory black interior.i want to paint my car back to the original color it was im just adding a modern clearcoat to it
Old Mar 15, 2013 | 12:47 PM
69442C's Avatar
The paint code is located on the cowl tag under the hood. Post a photo of it if you need help breaking down the codes.
Brian
Old Mar 15, 2013 | 01:06 PM
Follow Brian's suggestion to find the PNT code on the cowl tag. It will be a 2 digit number (actually 2 sets of numbers - one for lower body color and the second for upper) The lower one in this case will be the Paint code that you can reference here The other is the vinyl roof color with I believe is a letter. Likely B
Old Mar 15, 2013 | 09:35 PM
i will have to look tomorrow, i do have a picture of the car in my albums i dont know how to make it my profile picture yet
Old Mar 15, 2013 | 09:48 PM
Your 'Profile picture' is called an Avatar. To set it up:
1. clik the 'User CP' on the drop down bar under the C.O. banner.
2. In Your Control Panel, choose 'Edit Avatar' under the Settings and Options section
Follow the on screen directions and browse through your pics to find the one you want to use, or paste in the URL you want.
Clik 'Save Changes'.
You can also install your signature line by cliking the "Edit Signature' in the same area of the User CP.
Hope that helps you navigate through what you need. If you run into problems either post or send a PM and we'll git 'r done.
perro
Sep 8, 2012 07:45 PM
mathieuaube
Nov 29, 2008 11:21 AM
marzgtp1
Apr 18, 2008 11:48 PM
1968 42
Apr 12, 2008 07:32 PM
drtdobber
Mar 5, 2007 12:42 PM
