Radiator overflow nipple
Old Feb 24, 2008 | 04:30 PM
silverriff's Avatar
1972 Cutlass 455
Question Radiator overflow nipple
The radiator overflow hose nipple is missing on my 1972 Cutlass 455. After inspecting it, it doesn't look like anything was broken off, nor do I see any threads in there to screw in a fitting.Is this common? Do I have to flare/solder in a tube? Im tired of filling the radiator up. Any help would be great!
Old Feb 24, 2008 | 05:13 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
If you want to keep your overflow system, you will have to solder/repair it with a new tube.
If it's a plastic tank, I'd just plug it with a rubber washer and a machine screw&nut. Obviously, you can't solder onto plastic.
Octania
Aug 11, 2014 01:25 PM
W30Olds
Jan 27, 2014 06:28 PM
mugzilla
Mar 29, 2010 12:10 AM
ilandtime
Jul 4, 2008 03:01 PM
oldssragtop
Nov 26, 2006 06:57 PM
