housings in dash for lamps
Old February 29th, 2012, 01:28 PM
stlbluesbrother's Avatar
Question housings in dash for lamps
I forgot the name of the part mentioned in the Title of this thread. Never the less, see the pic below for an example.
Question: why is the texture grainy? And, why are sparkles mixed in with the color?
I want to paint these (there are 2 per dash), but want to know more before going about it. Thanks
stlbluesbrother is offline
Old February 29th, 2012, 05:26 PM
Lady72nRob71's Avatar
Dash floodlight housings.
They seem to have the same coating that many other little parts get, like clips, brackets, and smaller screws. I thought it is a plating called black oxide or manganese phosphate.
Someone will know for sure.
If you want to be very factory correct, I think Eastwood sells a paint much like that.
Keep in mind that once these are installed and the lenses installed, noone would ever be able to see them.
I found that Krylon high-heat spray paint has the same low sheen and color, just not the sparkles.
Lady72nRob71 is offline
Old February 29th, 2012, 06:06 PM
oldzy's Avatar
Mine are the same. Zinc Phosphate or similar finish as above originally. My gas pedal rod looks the same (that dull grayish color with sparklies). I was thinking of sending them off eventually to brakeboosters.com to have replated (same place I had my steering box done).
oldzy is offline
Old March 1st, 2012, 07:24 AM
thanks guys
Christophe2m6
October 31st, 2014 11:37 AM
Octania
October 5th, 2013 07:28 PM
ROCKET VAPOR
June 11th, 2013 10:17 AM
FATRATMATT
August 27th, 2008 07:31 PM
DuezPaid
November 3rd, 2007 01:21 AM
Quick Reply: housings in dash for lamps
