61 olds vaccuum diagrams?
Old Nov 7, 2007 | 02:34 PM
drgnbumpr63's Avatar
i havent been posting much just absorbing alot of info. but i was wandering if anyone has any info or could point me in the right direction. i've already purchased an origional shop manual but it didnt have the info i needed. i'm looking for a vaccum diagram for my 61 olds dynamic88. i think i'm missing a line going to my trans and hopefully that will solve my trans problems. thanks in advance for your help.
Old Nov 8, 2007 | 05:34 AM
thanks for the input. well when i put the car in gear it stalls out, now i'm used to working on classic chevy's and that symptom usually points to a vaccum leak. also on the passenger side of the engine compartment there is a metal tube that comes up from under the car with a small canister on it and then it sort of hooks down and it looks like a vaccum line of some sorts. any idea what that is?
Old Nov 8, 2007 | 06:01 AM
i work for an independant parts jobber and we sell mostly napa parts.
Old Nov 8, 2007 | 08:31 AM
yep, it's a 2bbl. i just had a local resto. shop rebuild it for me. the problem was there before i had that done. i also just replaced my b/b becuase there was a leak in that, so i'm planning on replacing all of my vaccum lines.
Old Nov 9, 2007 | 08:47 AM
KQQLCAT's Avatar
Your shop manual should have a diagram for vacuum lines mine does and sure helped me out. Mine were all cobled together with "t" conectors. I replaced all the lines in mine also because they were pretty briitle.
Pat
rodan
Jun 18, 2014 07:41 PM
tds
May 7, 2013 10:29 AM
Big Blue 72
Mar 1, 2013 10:49 PM
rloxton
Mar 21, 2010 05:57 PM
millwrightrice
Jul 28, 2008 03:26 PM
