61 olds vaccuum diagrams?
i havent been posting much just absorbing alot of info. but i was wandering if anyone has any info or could point me in the right direction. i've already purchased an origional shop manual but it didnt have the info i needed. i'm looking for a vaccum diagram for my 61 olds dynamic88. i think i'm missing a line going to my trans and hopefully that will solve my trans problems. thanks in advance for your help.
thanks for the input. well when i put the car in gear it stalls out, now i'm used to working on classic chevy's and that symptom usually points to a vaccum leak. also on the passenger side of the engine compartment there is a metal tube that comes up from under the car with a small canister on it and then it sort of hooks down and it looks like a vaccum line of some sorts. any idea what that is?
yep, it's a 2bbl. i just had a local resto. shop rebuild it for me. the problem was there before i had that done. i also just replaced my b/b becuase there was a leak in that, so i'm planning on replacing all of my vaccum lines.
Your shop manual should have a diagram for vacuum lines mine does and sure helped me out. Mine were all cobled together with "t" conectors. I replaced all the lines in mine also because they were pretty briitle.
Pat
Pat
rloxton
Mar 21, 2010 05:57 PM
