72 Cutlass Console Lock
Old Apr 24, 2024 | 12:12 PM
george@BWR's Avatar
How can I remove the lock from the center console of my car? It works but there is play in the lid when it is closed and I am trying to get it adjusted for a better fit.
Old Apr 24, 2024 | 01:59 PM
The lock assembly is held in with a small screw that holds the lock cylinder in a housing. The cylinder inserts from the outside, the housing from the inside, and the screw holds the two together, with the console sandwiched between the two.
With that said, there is no adjustment in the lock cylinder to take up that vertical slack. The catch on the lid is the only place to make any adjustments, but be VERY careful if you attempt to bend it as the metal is very hard and can snap. That happened to me back in the 80s, and I had to drill a hole in the remaining section to catch the hook on the lock cylinder.
Old Apr 24, 2024 | 02:49 PM
george@BWR's Avatar
Thank you. There is an indentation on the outside of the console where you insert the key and it looks like the lock is not in the center of that indentation. I thought if I could loosen the lock and may be able to cneter it and get a tighter fit.
Old Apr 24, 2024 | 07:06 PM
The lock cylinder should be centered in the well, so your theory might be right. There’s a small screw on the inside of the lock assembly. Remove that screw and the lock cylinder and housing can be removed from the console.
Old Apr 25, 2024 | 05:48 PM
george@BWR's Avatar
Thanks, I will give it a try.
Old Apr 30, 2024 | 06:05 PM
george@BWR's Avatar
Loosened the lock and moved it down. The door of the console latches the way it should with no play in the lid.
Old Apr 30, 2024 | 08:09 PM
Glad to hear you got it corrected.
hjohn18800
May 7, 2022 03:46 PM
hjohn18800
Jul 9, 2021 07:33 AM
Gerald Nickels
Mar 3, 2018 03:00 PM
Eastflorida
Nov 12, 2017 10:01 PM
