Searching for 1966 Delta 88 Convertible Gear Shift Indicator
If this is all you need (see Image below) Jegs list them on their site,and also on EBay for 4 speed automatic (all 4" Columns). If you need the complete column EBay list chrome column complete that says it will fit a 1966 Oldsmobile. Larry
Exactly what part are you looking for? Unless you have a floor shift, the gear indicator is integrated into the dash. Do you need the clear lens with PRNDSL? Do you need the needle? Do you need the link from the needle to the steering column?
Thank you both for the replies.
Rocketowner: Would it be possible for you to send a link to that part on Jegs? I couldn't find it.
Joe: All I need is the clear lens with PRNDSL. Do you have any ideas on places I could check? I would like to find an original part if possible.
Thanks again.
Thanks again.
Did I miss something? I thought the OP was looking for an OEM indicator that goes in the dash?
Joe ,sorry, I was under the impression that he was unable to find any of the original parts that went in the dash,that you was referring to in post #3, and I was giving him another option ,if the original parts could not be purchased. Reading post #4 he stated "Joe ,all I need is the clear lens with PRNSLR, and ask you if you had any ideas of places he could check ,that he would like to have the original part if possible. Since you did not answer ,I and probably he, thought the original clear lens was not available. Larry
The 1966 dash and indicator is different from the 67-68 part you posted.
Olds 64: Thanks, but that isn't the part I need. I am located in north Louisiana.
Larry: Yes, that looks like what I need. I am attaching a picture of the dash in my car.
If 'jcdynamic88's part doesn't work out, I've got this one. No cracks or breaks. There's a thin piece of something like paper on the front of it that has a small tear on the bottom. Looks like the bezel is chipped but it's not. $25 plus the shipping.
rothlane'68
March 31st, 2016 10:48 AM
Dangerbird
February 18th, 2013 11:54 AM
Flye
April 25th, 2011 08:08 AM
