Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Steering wheel medallion removal
Old Mar 19, 2026 | 08:05 PM
Delbertdelmont's Avatar
I don’t have a shop manual for the Delmont 88 in my hands yet so I don’t know the trick for removing the central steering wheel medallion. I assume the inner horn switch screws are concealed beneath it. I’ve gingerly twisted and pulled and it doesn’t release.
I need to remove the horn switches for cleaning/repairing the intermittent contacts.
Old Mar 20, 2026 | 06:13 AM
Year and which steering wheel would help
Old Mar 20, 2026 | 08:42 AM
This one 1967
This one….
Old Mar 20, 2026 | 09:41 AM
Ran across a photograph of a Delta 88 steering wheel and saw where the clips engage into the steering wheel. Inserted my fingernails, gritted my teeth and pulled. I figured they would snap off first.
I realize now that the clips are made sensibly of steel and there was nothing fragile to break. Contacts are cleaned of oxidation, treated with Vaseline and now it’s honking reliably.
Old Mar 20, 2026 | 11:20 PM
cfair's Avatar
The retaining ring which retains the plastic trim is made of spring steel which will yield (unclip) under sufficient force. In '66 there were 2 prongs or "ears" that secured the ring/medallion to the column. I suspect, but don't know, they used the same or similar design in 1967.
For reference, the hairline cracks in the plastic medallion are par for the course. If you find one that's crack-free, snap it up. 90% of these medallions cracked up over the past 60 years. Beneath the medallion is a Saginaw-made steering column which shares many design features and some parts with other GM cars of the day. See my posts on the '66 tilt & tele column repair for reference.
Basically, the plastic parts can wear out and crack/break, but the brass contacts, electrical grounds and what not are very durable. If your plastics is/are broken, you're probably buying another column to get good replacements since 196x big Oldsmobile columns are not in high demand. No, Cutlass/442 parts probably won't work.
There are a few people working on 3D printing replacement parts for the long-gone plastic parts. I wouldn't call it a market, but you might just be able to find someone who can reproduce any failed/cracked/broken plastics if you can provide an original part to make a pattern from.
My own approach is a stash of '66 Big Car tilt & tele columns stored under my house to cannibalize as needed.
Cheers
Chris
Old Mar 24, 2026 | 10:28 PM
Cheers
Chris
Thanks for the information Chris.
I sort of identify with a crazed medallion so I don’t mind. A little update, the brakes are done and just need to be bled. It’s almost ready for tags and insurance!
Speaking of cannibalism I have found a four door 1967 Delta 88 four door for parts that seems to be in good condition.
Is it safe to assume that the chrome eyebrows over the headlights are interchangeable between the delmont and delta? I would like to use the Delta bumper to replace my rusty one but I would have to discreetly relocate the delta front turn signals somehow, since Delmont bumpers have turn signals incorporated.
It has some rust in the trunk seal rail across the rear and at the corner gussets so I’m hoping that section is similar enough between the holiday coupe to use for repairs. My front fenders have a little badly applied Bondo so having a little nicer set also helps to justify the cost parts car.
your thoughts are appreciated.
FINISHLINE
Oct 9, 2022 12:14 PM
FN723
Jun 18, 2019 06:39 PM
neatolds
Aug 23, 2015 08:36 AM
65OldsDelta88SuperRocket
Nov 13, 2011 05:46 AM
CheckM8t
Apr 24, 2007 06:24 PM
