vacuum cannister connection?
Old April 14th, 2016, 09:09 AM
Peter Lufrano's Avatar
Hi again!
My '71 cutlass convertible has a black cylindrical vacuum cannister mounted to the firewall.
One port is connected to manifold vacuum, the other port seems to have been capped off.
Can one of you knowledgable guys tell me where this capped off port should be connected to? and perhaps its location so I can know where to find it?
Many thanks in advance!
Peter Lufrano is offline
Old April 14th, 2016, 10:00 AM
That is the vacuum source for the HVAC controls. I'm not sure where it connects under the dash, though, as I never had to trace it. All I have seen on my car is the vacuum line coming out of the firewall and connecting to the vacuum canister.
Fun71 is offline
Old April 14th, 2016, 10:27 AM
Ah, thank you for the reply Fun71.
Anyone know where to look for the connection point?
Old April 15th, 2016, 06:07 PM
The vacuum canister is simply an additional vacuum tank that provides vacuum to operate the HVAC flapper doors during periods of low manifold vacuum (like wide open throttle). The port closest to the engine connects to the manifold vacuum source. The port closest to the firewall goes through the firewall and connects to the A/C control head. Your chassis service manual has the hose diagram and connections.
joe_padavano is offline
Old April 15th, 2016, 07:28 PM
Thank you Joe!
Where do I find this "A/C control head"? Is this the actual control panel assembly in the dash of the car by chance?
Old April 16th, 2016, 04:37 AM
Yes it is.
MDchanic is offline
Old April 16th, 2016, 05:06 PM
Originally Posted by MDchanic
Yes it is.
Thank you Eric!
Now if my Chassis service manual will just arrive already!
Old April 16th, 2016, 05:15 PM
If you need an immediate fix, you can always join the nonprofit Historical Society at WildAboutCars.com for about $25 and download as much as your bandwidth will allow.
MDchanic is offline
Christophe2m6
October 12th, 2015 04:53 PM
johns59super88
October 29th, 2013 08:22 AM
The Bug Man
March 19th, 2013 06:00 PM
Gary's 2 442-S
March 31st, 2010 04:19 AM
1971 442 convert
February 17th, 2010 09:22 AM
Quick Reply: vacuum cannister connection?
