vacuum cannister connection?
Old Apr 14, 2016 | 09:09 AM
Peter Lufrano's Avatar
Hi again!
My '71 cutlass convertible has a black cylindrical vacuum cannister mounted to the firewall.
One port is connected to manifold vacuum, the other port seems to have been capped off.
Can one of you knowledgable guys tell me where this capped off port should be connected to? and perhaps its location so I can know where to find it?
Many thanks in advance!
Old Apr 14, 2016 | 10:00 AM
That is the vacuum source for the HVAC controls. I'm not sure where it connects under the dash, though, as I never had to trace it. All I have seen on my car is the vacuum line coming out of the firewall and connecting to the vacuum canister.
Old Apr 14, 2016 | 10:27 AM
Ah, thank you for the reply Fun71.
Anyone know where to look for the connection point?
Old Apr 15, 2016 | 06:07 PM
The vacuum canister is simply an additional vacuum tank that provides vacuum to operate the HVAC flapper doors during periods of low manifold vacuum (like wide open throttle). The port closest to the engine connects to the manifold vacuum source. The port closest to the firewall goes through the firewall and connects to the A/C control head. Your chassis service manual has the hose diagram and connections.
Old Apr 15, 2016 | 07:28 PM
Thank you Joe!
Where do I find this "A/C control head"? Is this the actual control panel assembly in the dash of the car by chance?
Old Apr 16, 2016 | 04:37 AM
Yes it is.
Old Apr 16, 2016 | 05:06 PM
Originally Posted by MDchanic
Yes it is.
Thank you Eric!
Now if my Chassis service manual will just arrive already!
Old Apr 16, 2016 | 05:15 PM
If you need an immediate fix, you can always join the nonprofit Historical Society at WildAboutCars.com for about $25 and download as much as your bandwidth will allow.
Christophe2m6
Oct 12, 2015 04:53 PM
johns59super88
Oct 29, 2013 08:22 AM
The Bug Man
Mar 19, 2013 06:00 PM
Gary's 2 442-S
Mar 31, 2010 04:19 AM
1971 442 convert
Feb 17, 2010 09:22 AM
