Is my HEI too HE-HIGH?
Old Jun 4, 2007 | 12:58 PM
TheRuss's Avatar
First off, sorry for the play on words. You have my sincere apologies. Here's a pretty random question.
When I bought my '72 Cutlass S (350, 2bbl, daily driver), it had been converted to HEI and had an aftermarket air cleaner on it already (Mr. Gasket or something). I recently bought the original air cleaner from someone online for super cheap, but when I tried to put it on, the distributor cap seemed to be a little too tall for the air cleaner to fit....I didn't want to force it on there.
I was wondering if anyone with a 68-72 Cutlass with a 350 and HEI is successfully using their original air cleaner housing?
Old Jun 12, 2007 | 10:47 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I used a spacer between the carb and the air cleaner and it raised the air cleaner enough to clear the distributor. I bought it years ago when Super Shops was still in business. I forgot who make it but am sure somebody still does.
Old Jun 12, 2007 | 10:50 PM
redoldsman's Avatar
Sorry I just realized after I posted that you have a 2 barrel. Mine is quadrajet. I doubt you will find a spacer. You will probably have to modify the air cleaner but it will be worth the effort.
Old Jun 13, 2007 | 05:52 AM
TheRuss's Avatar
Air Cleaner Size
Thanks for the reply, Red.
It's good to know that others had the same problem. I was wondering why the car had an aftermarket air cleaner when the rest (other than the HEI) was basically factory.
Yeah, I'm not having an easy time finding a riser for my 2bbl. Although I'd love to have the ROCKET 350 air cleaner rockin', I'm more concerned about the fact that I need to use a cheap plastic adapter to fit the aftermarket (which was intended for a 4bbl) onto the two barrel. I'm just not sure I'm getting a tight connection there. It gets all warped by the heat of my engine, and doesn't really fit the bottom of the cleaner very well.
Mr. Gasket sells a 4-in air cleaner that's designed for 2bbls. I may get this until I fashion a riser for my factory air cleaner.
Does anyone know if there is a correlation between air cleaner size and performance? I've always wondered that.
Thanks Olds buddies! See you next weekend at the Carlisle, PA All GM Nationals!
Russ
Old Jun 13, 2007 | 08:30 AM
Redog's Avatar
^^ I'll be in Lansing for the Homecomming show
Old Jun 13, 2007 | 08:59 AM
TheRuss's Avatar
That's sweet! I wish I could go...maybe next time.
Hope you have an awesome time.
Russ
EightballZ
Aug 24, 2015 04:56 AM
Macadoo
Jun 24, 2014 05:36 PM
joepenoso
Jun 4, 2014 01:56 PM
RSmith8
Nov 1, 2013 02:22 PM
agtw31
Jul 20, 2009 09:58 AM
