Lower radiator hose
Old Oct 1, 2009 | 10:07 AM
radioburningchrome's Avatar
Lower radiator hose
Picked up part # 7357 from NAPA for my 65 Delta 88 425/2. Lower hose does not have a spring like the original.
Salesperson told me "newer" hose technology prevents hoses from sucking shut.
Is this true?
Old Oct 1, 2009 | 10:16 AM
Nilsson's Avatar
Is this true?
I find that the spring usually applies to the ribbed generic type hoses. These usually have a thinner wall. So what he says may have some merit. My bottom hose does not have a spring and no problems here.
Old Oct 1, 2009 | 10:34 AM
Lady72nRob71's Avatar
The lower RAD hoses I have recently bought for 4 different cars have NOT come with springs. They were either Gates brand or AC Delco. In most cases I pulled the springs from the old ones and twisted them into the new ones.
Given the stiffness of most of the new hoses, the springs may not be required.
Old Oct 1, 2009 | 10:52 AM
My new lower radiator hose didn't have the spring. I removed the spring from the old hose and installed it in the new one just to be safe.
Old Oct 1, 2009 | 11:51 AM
svnt442's Avatar
I tried to do that, but the hose was a smaller diameter and the spring wouldn't fit...ugh.
Old Oct 1, 2009 | 01:13 PM
It cannot be too much smaller than the original hose in order to fit.
Try "screwing" it in while pushing it in. Doing so will narrow out the spring, allowing it to go in. This has worked for me. They will not "drop right in".
Old Oct 1, 2009 | 01:37 PM
I had to use some twine to pull the spring through the lower radiator hose. It went partially into the hose but I had to "flex" the hose while pulling on the twine to get it through the last bend.
Old Oct 1, 2009 | 02:06 PM
svnt442's Avatar
The end of the hose was the dame size and the olds one, but it necked down about 4" in.
Old Oct 6, 2009 | 05:04 AM
I try to stay away from the "flex" hoses. Past experiences were not good.
Old Oct 6, 2009 | 05:05 AM
Sounds like a good idea.
I will try it out this weekend.
Old Oct 6, 2009 | 06:37 AM
Let us know if it works.
Old Oct 6, 2009 | 06:53 AM
Nilsson's Avatar
X2 no flex or ribbed hoses here. I use quality thick wall hoses which are actually from one of the Oldsmobile repro places. Don't have to worry about the springs and all that junk.
Pay an arm and a leg though.
Old Oct 7, 2009 | 05:11 PM
I have also had bad experience with flex hoses. It is better to pay an arm and a leg for a radiator hose for a 394, 371, 303, etc. than have an engine that blows a radiator hose. You can buy most hard to find hoses from Fusicks or Kanter. The good thing about having a 455 is that most hoses are available from the local auto parts store.
jjokrm
Dec 27, 2012 08:30 AM
belairbob
Sep 27, 2012 07:09 PM
matviar
Apr 9, 2012 12:56 PM
jdanieljones
Dec 28, 2008 01:55 PM
harleyrules
Nov 25, 2007 07:22 PM
