Hurst Dual Gate shifter question
Old Feb 28, 2011 | 05:58 PM
Beob's Avatar
This shifter has been in my 69 442 as long as Ive owned it (20years). It never had a nuetral/back-up switch, and I would like to install one. I believe the shifter is from 68 or 69. I bought a switch from fusick and cant see how it hooks up, am I missing something or will it just not work with this shifter? Does anybody have this same shifter. Any help appreciated
Thanks, Rob
Old Feb 28, 2011 | 06:33 PM
firefrost gold's Avatar
try performance years.com thats a pontiac dual gate . since olds didnt put that style in maybe its goig to differ from what you have good luck.
Old Feb 28, 2011 | 07:03 PM
Cameo White's Avatar
Smile
The style looks similar to the 68-69 H/O Dual Gate. Those have a specific neutral/back-up safety switch that is damn near impossible to find--and doesn't look anything like the one in your picture. Someone did email me with a link to a repro recently--I'll see if I can find it. I would take Firefost's suggestion first, though. With a straight stick, that is an original Pontiac shifter.
Old Feb 28, 2011 | 07:34 PM
Yes, it is.
Old Mar 1, 2011 | 07:40 AM
Beob's Avatar
Thanks for identifying it as a pontiac shifter but I had no luck at performance years.
Rob
Old Mar 1, 2011 | 10:45 AM
Bluevista's Avatar
Registered
Ames Performance has the neutral safety/back up lamp switch for the '68 Poncho His-Hers shifter.
Why not just put on back drive linkage?
Or doesn't that column have a provision for it?
http://www.amesperf.com/html/download.html
Old Mar 1, 2011 | 01:03 PM
bigdaves442's Avatar
Ok, it looks like you have a 1970 olds only Neutral safety switch that you are trying to use with a pontiac shifter, thats why it doesn't look right. That rectangle switch that you have needs a special mounting bracket made just for the 1970 olds (parts place sells them) but i'm not sure it will work with that shifter.
The correct Neutral safety switch for the shifter that you have looks like a half moon and mounts up in the front of the shifter.
Here is a link of the breakdown of the shifter, the correct switch and where it should be mounted:
http://home.comcast.net/~witrob/dual/dual.html
Old Mar 1, 2011 | 01:16 PM
hurst68olds's Avatar
don't know if this helps .... here are a few '68-'69 dual gate/neutral swtch pics
Old Mar 1, 2011 | 01:34 PM
ebay has lot of parts too.
Old Mar 1, 2011 | 03:38 PM
Thats the correct switch he needs right there.
Old Mar 1, 2011 | 04:17 PM
here's a repro switch on ebay - http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Mar 1, 2011 | 07:51 PM
Beob's Avatar
Thanks for all the help, much appreciated!!
Hurst/Olds
Nov 27, 2010 09:02 PM
RS3SDL2MG
Hurst/Olds
Oct 7, 2009 05:42 PM
1968 42
Apr 3, 2008 05:15 PM
