edelbrock 1406 how to rebuild/kit questions
Old Mar 24, 2014 | 03:51 PM
billmerbach's Avatar
major noob
Ok since I'm getting my edelbrock 1406 from oldspackrat in a few days I need to know which is the best rebuild kit to buy and should I get the calibration kit from edelbrock (probably not) and is there any kind of special things I should do as rebuilding it needs to be just right
Old Mar 24, 2014 | 04:34 PM
scooter123's Avatar
rebuilt mine last year....cant remember the part #......will go to the garage in a bit and get it for ya!!
I used edelbrock Part # 1477
Old Mar 24, 2014 | 04:41 PM
major noob
Ok how well did yours run afterwards
Old Mar 24, 2014 | 04:42 PM
scooter123's Avatar
Ran great!!
Old Mar 24, 2014 | 04:43 PM
major noob
Awesome was it easy?
Old Mar 24, 2014 | 04:47 PM
oldstata's Avatar
Justin
Eddies are exstreamly easy to rebuild just take it apart slowly look at everything as you do it it comes with pretty good instructions and in a clean place I know you have a little brother so make sure he doesn't move stuff around on you lol
Carb cleaner these days aren't as good as they used to be
Old Mar 24, 2014 | 04:50 PM
major noob
Ok what can I use to get the shine back on it its pretty dirty will a mild degreaser work
Old Mar 24, 2014 | 04:53 PM
oldstata's Avatar
Justin
I soaked mine for a few hours in the carb cleaner bought a 5 gal at napa it wasn't the best stuff but it was cheap it got most if the shin back in that prosses
Old Mar 24, 2014 | 04:55 PM
major noob
Ok
Old Mar 24, 2014 | 05:01 PM
oldstata's Avatar
Justin
Bill I know this might be awhile but run new rubber lines from carb to fuel pump and pump back to the gas tank steel lines are proble okay but check them make sure they are not rotted out I would also put a fuel filter in line before the car
Old Mar 24, 2014 | 05:22 PM
Magna86's Avatar
Another cheap safe carb cleaner is Pinesol. You dilute it 50/50 and soak the carb pieces in it for a day or two. Makesure to wear rubber gloves as it will dry out your hands if you are in it too long. Wont hurt any rubber or plastic bushing. Finish cleaning the carb with warm water, then use compressor air or spray carb cleaner to dry out the passages. I use this trick on my holley for the 71 and all of my motorcycle carburetors. PLus you have left over cleaner you can use on the floor or any other parts you need to clean. :-)
Old Mar 24, 2014 | 05:34 PM
major noob
I have two bottles of this orange spray cleaner it has citrus oil on it I think I'm thinking of cleaning up the outside with that
Old Mar 25, 2014 | 07:54 AM
major noob
Scooter were you able to get me a part number
Old Mar 25, 2014 | 09:31 AM
R-body_mopar's Avatar
Question
Is this the one you need?
http://store.edelbrock.com/1477maste...undercarb.aspx
My question is, what engine are you using this on, and what manifold? This is a square bore carb, and you need the proper adapter and gaskets to use on a spread bore (Quadrajet) manifold.
As for the tuning kit, I would recommend it, as today's gas is much different than the gasoline of old, and may require some fine tuning of jets, metering rods, or springs. I did this swap years ago on a 1988 Dodge Diplomat police 318, to replace a stock Rochester Quadrajet O2 feedback carb, and it took a bit of tweeking to get it right!! It eventually ran very well.....but fuel mileage suffered to the tune of about 5 mpg's!
Full instructions should be available for download on the Edelbrock home site!
Old Mar 25, 2014 | 09:50 AM
major noob
You have a diplomat I have a gran fury!!! Lol and I have the adapter as well coming olds packrat set me up good I'm not sure I want to get the biggest kit for my money and I'll replace the float as well just to be on the safe side
Old Mar 25, 2014 | 12:28 PM
scooter123's Avatar
I used 1477.... I think it's the right one...... Cross ref it on there web site
Old Mar 25, 2014 | 12:36 PM
major noob
Ok thanks guys
Old Mar 25, 2014 | 04:09 PM
major noob
Good deal?
Old Mar 25, 2014 | 06:08 PM
oldstata's Avatar
Justin
Yeah that isn't bad I think I spent like 40 at the local parts store for my rebuild kit it didn't come with floats tho I just adjusted them
Old Mar 25, 2014 | 06:11 PM
major noob
Ok I think I'll buy it carb should be here tomorrow boy oh boy ik this isn't the vest aftermarket carb but I've always wanted n Eddie and now I'm getting one. Ive watched videos and these carbs look to have excellent throttle response
Old Mar 25, 2014 | 06:13 PM
oldstata's Avatar
Justin
Lol depends I think they lag a bit from a well tuned q jet but I like how easy they are to rebuild
Old Mar 25, 2014 | 06:19 PM
major noob
Yea I wanna take a while to rebuild it as its the only engine e work I'll be doing till I get everything else
Old Mar 26, 2014 | 09:01 AM
Wink
I agree about the throttle response, but they are simple to rebuild, and don't leak (LOL), but mileage and throttle response is definitely better from the Qjet and Thermoquad, as they have smaller primaries, which is where you run MOST of the time.....
Old Mar 26, 2014 | 09:45 AM
Question
That is a good price, I think, but I haven't checked around at all.
The Edelbrock is more sensitive to fuel pressure, and float level than most others, so be sure and set the floats PERFECTLY!
Here is a link to Edelbrock instalation/tuning:
http://www.edelbrock.com/automotive/...h-videos.shtml
And here is an interesting read into tuning problems:
http://vb.foureyedpride.com/showthre...6-Carb-Read-On
http://www.carcraft.com/techarticles/carb_tuning/
Old Mar 26, 2014 | 09:52 AM
major noob
Can I make the primary smaller
Old Mar 26, 2014 | 02:45 PM
Red face
The size of the primaries I was refering to is the diameter of the throttle bores, not the size of the primary carburetor jets or metering rods.
If I recall, the Edelbrock has equal size primary and secondary bores, whereas the Qjet and Tquad have small primaries, and larger secondaries.
Fuel economy and throttle response are determined by intake velocity, and smaller bores usually result in higher velocities, therefore better low speed response and better fuel economy; BUT, when you open the secondaries....the whole thing changes! Lol!
This is a simple explanation, not a technical one......no attempt is being made to explain the workings of any carburetors!
Old Mar 26, 2014 | 03:06 PM
major noob
Ahhhh I gotcha lol still waiting on it to arrive lol
Old Mar 28, 2014 | 02:07 PM
major noob
Need help the little screws broke off that hold the round plates to them rods in the bottom of the carb
Old Mar 28, 2014 | 03:38 PM
stan 65 cutlass's Avatar
Old Mar 28, 2014 | 03:40 PM
major noob
Originally Posted by stan 65 cutlass
6of 8 came out fine I need the throttle shaft now as I tried drilling but couldn't stop shaking and messed up
Old Mar 28, 2014 | 05:18 PM
  #31
dont feel bad it happens, i broke off 3 of 4 mounting bolts for my wipers and then broke 2 of 4 bolts off my parts car as well. with some heat they will come out. good luck.
Old Mar 28, 2014 | 05:29 PM
  #32
major noob
Well I'm on the lookout for a parts carb if anyone has one
Old Mar 28, 2014 | 06:06 PM
  #33
oldstata's Avatar
Justin
Bill I have just the base but I think it's from a reman one can you post some pics of what happen to the current one
Old Mar 29, 2014 | 10:09 AM
  #34
Unhappy
Unless the carb is completely worn out, there is NO NEED to remove the throttle blades from the shaft; they are staked in from the factory, and only need to be cleaned thoroughly with solvent. If the throttle shaft or base is worn badly enough, you will need to replace the shaft and drill and install new bushings....but this would be a rare case on a carb that is already a replacement for a worn out original carb...
Old Mar 29, 2014 | 10:18 AM
  #35
BLUE72RAGTOP's Avatar
Can you drill an oversize hole and use a larger size screw? Ground off excess and Stake and lock-tite.
Old Mar 29, 2014 | 11:32 AM
  #36
major noob
Yea r body it was another one of my dumb ideas I was cleaning and forgot to realize I don't need to take out these butterflys I'm gonna end up in trouble if I don't slow myself down and think
Old Mar 29, 2014 | 02:45 PM
  #37
oldstata's Avatar
Justin
Okay guys, I am not a carb experts so let's help bill out. I have just the lower base looks like a Eddie base I need to dig it out I was going to use it awhile back but mine ended up being good, so here is the question. it's a reman base so the numbers are no good to compare to the 1406 are the bases the same and just the guts different ??
christine fury
Mar 13, 2017 05:54 AM
jimjr
Jan 17, 2010 11:48 AM
jimjr
Aug 20, 2009 06:25 AM
agtw31
Apr 11, 2009 06:57 AM
Huron
Jul 9, 2007 11:56 AM
