72 Cutlass Console Lock
The lock assembly is held in with a small screw that holds the lock cylinder in a housing. The cylinder inserts from the outside, the housing from the inside, and the screw holds the two together, with the console sandwiched between the two.
With that said, there is no adjustment in the lock cylinder to take up that vertical slack. The catch on the lid is the only place to make any adjustments, but be VERY careful if you attempt to bend it as the metal is very hard and can snap. That happened to me back in the 80s, and I had to drill a hole in the remaining section to catch the hook on the lock cylinder.
Thank you. There is an indentation on the outside of the console where you insert the key and it looks like the lock is not in the center of that indentation. I thought if I could loosen the lock and may be able to cneter it and get a tighter fit.
The lock cylinder should be centered in the well, so your theory might be right. There’s a small screw on the inside of the lock assembly. Remove that screw and the lock cylinder and housing can be removed from the console.
