69 Cutlass LH Mirror Help
Old Jan 25, 2026 | 11:00 AM
SFE's Avatar
SFE
Hi, need help finding the proper mirror or part number for my 69 cutlass 's' holiday 2 dr coupe.
The foam gasket is still attached to the door and measures 5-3/8" long x 1-1/8" wide.
Every remote and manual adjust mirror I have found has a base 3-7/8" long.
Old Jan 25, 2026 | 02:54 PM
Texas69's Avatar
69 mirror
Check here for part numbers and info.
https://classicoldsmobile.com/forums...16/#post702560
Old Jan 25, 2026 | 05:03 PM
Olds didn't use foam gaskets, nor did they use sheet metal screws to mount mirrors, so your parts are not OEM. The factory mirrors used screws that fit into those large keyhole slots in the door and used a molded plastic gasket. Your parts are aftermarket.
Old Jan 26, 2026 | 05:27 AM
SFE's Avatar
SFE
Appreciate the info greatly!
Old Jan 26, 2026 | 11:00 AM
2blu442's Avatar
Are you looking for part numbers to the remote adjustment mirror or the one you have to roll down the window and adjust by hand?
Old Jan 28, 2026 | 08:26 AM
The correct manual outside mirror package for the 68-69 cars is P/N 231265, which is the number for the mirror assembly including gasket. It is not the casting number you will see on the underside of the pedestal. It looks like this.
The casting number on the underside of the pedestal is 400543.
The correct gasket looks like this.
My2nd 69 442
Nov 14, 2017 05:20 PM
69ishHoliday
Nov 2, 2014 09:39 AM
rr69ho
Apr 5, 2014 08:08 AM
luddie
Dec 11, 2013 04:07 AM
cheven
Jun 20, 2012 01:57 PM
