BBC Forged Crank
If I am wrong let's identify it. I'm going off what another member said. Would a picture of the flywheel flange help? If it a different crank what's it worth so I can find a new home for it.
There are no casting numbers or lines on the crank. Only numbers are whats stamped into the counterweight that I listed in the original post. Its aftermarket but I don't know by who.
Rods are 2.38 and mains are 2.70 if this helps anyone I'd this crank. This is with tape and a tape measure then divide by π
I'm trying to help you, but it is your responsibility not to misrepresent something, not mine.
There is not a casting number because it is not a CASTING but an aftermarket forged crank.
Aftermarket cranks did not typically have forged in numbers but stamped numbers as you showed..
It has a dual keyway as it was likely built for a supercharged application.
Reposted thread closed
Found out it's a top fuel crank that can't be run in a street motor unless machined for pilot bushing/ torque converter
