Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Chevy mounts cause yoke to stick out
Old October 4th, 2018, 11:01 AM
Carljrfc20's Avatar
Just dropped a chevy 350 in the 72 Cutlass S. Motor mounts cause the engine to sit closer to the front. Yoke on the driveshaft sits out the tranny a little. Should I modify the mounts or buy a longer yoke?
Carljrfc20 is offline
Old October 4th, 2018, 11:07 AM
Carljrfc20's Avatar
Trans type
It's the original 350 trans with an adapter plate connected to an 87 k10 350.
Old October 4th, 2018, 12:01 PM
72 Olds CS
RetroRanger's Avatar
I dont know the answer but did you change the frame pads and motor mounts ?
RetroRanger is offline
Old October 4th, 2018, 12:11 PM
Carljrfc20's Avatar
Both were removed to make the new mounts fit.
Old October 4th, 2018, 12:23 PM
I don't see a problem if you have around 3/4 of an inch sticking out. That gives the driveshaft room to move in and out.
oldcutlass is offline
Old October 4th, 2018, 03:39 PM
Carljrfc20's Avatar
Thanks, I forgot about having room to move.
ergot71
February 18th, 2020 05:38 AM
74 fastback
October 5th, 2015 05:29 PM
Finn5033
April 21st, 2012 02:14 PM
jo75olds
April 25th, 2011 07:51 AM
panos
February 24th, 2010 05:08 PM
Quick Reply: Chevy mounts cause yoke to stick out
