Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Radiator hose for 70-72 Cutlass with LS
Old Feb 19, 2016 | 08:43 PM
CutLS's Avatar
What are people using for their upper and lower radiator hoses using a dual pass radiator? I looked at my local parts store with some mock up bent wire but i couldn't did ones that had the right bend. I ended up buying the flex hose but my upper hose has been pulling at the clamp because of the flex in it.
Old Feb 20, 2016 | 06:47 AM
Octania's Avatar
What about two L's, to suit, joined at the center. Brace the joint to the motor and cover the joint with a decorative/ concealing thing. I wonder if clinch-on CV boot type clamps can be used on radiator hose. Tpically they are seen on lo-pressure hose of small diameter such as the PS return hose. You could surely glue the hoses to the joinery piece in addition to clamps, to help ensure it stays together.
Old Feb 20, 2016 | 06:13 PM
CutLS's Avatar
I just saw a similar kit in a catalog. I might try that if I can't find one.
Old Feb 21, 2016 | 06:23 AM
garys 68&72's Avatar
I posted the lower hose over at the "other forum". But for top hose, I've soldered together 1 1/4" copper pipe fittings to make a rigid pipe connected with rubber hoses at each end. Works well for complicated shapes since you can get various angles and clock them as needed.
Old Feb 21, 2016 | 01:20 PM
Krom's Avatar
found this:
For the upper hose, the upper hose from a 1995 Mitsubishi Eclipse turbo all wheel drive is almost a perfect fit
here:http://www.entropyrad.com/1968-1977-...um-shroud.html
Old Feb 21, 2016 | 02:28 PM
CutLS's Avatar
I just got back from O'Reilly looking for an upper radiator hose. I took a picture of my setup now and did measurements and went in with that. I found one that's basically perfect. It's a Master Pro 20795 hose. It has basically the perfect bend. It wants to flex one way is just slightly but not much. Now I just need to put my new clamps on and fill it back up.
Old Mar 1, 2016 | 05:19 PM
csouth's Avatar
If you want to get rid of the lower flex hose, check Dayco 71013.
Old Mar 1, 2016 | 07:14 PM
CutLS's Avatar
I ended up getting Masterpro 21736, it's a version of NAPAs 7499. I found some people using Napas 9070. The one I got looks like it drops down after the thermostat. I haven't installed it yet.
6884rocket
Sep 24, 2015 04:52 PM
Sampson
Mar 24, 2015 09:33 AM
matviar
Apr 9, 2012 12:56 PM
njot33
Feb 25, 2008 08:18 AM
harleyrules
Nov 25, 2007 07:22 PM
