Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Looking for info on 350/350 swap into 61 olds 88
Old June 1st, 2014 | 09:33 PM
oldrelics's Avatar
Okay, I'm just about done with the 394/slim jim. Time to start preparing for the inevitable, the SBC 350/TH350 insert. Anybody else done it? Tips n tricks?
No, I'm not spending a nickel more on trying to keep the heap going. Its my families more-door, so purists back away.
Also looking forward to the front end losing 300 lbs.
Old June 3rd, 2014 | 09:11 PM
Summerof84's Avatar
Using the factory driveshaft, a longtail th400 just barely makes it back to the firewall. If a th350 is even 1" shorter, it's going to make a difference. Otherwise a custom driveshaft has to be added to the tally.
Old June 3rd, 2014 | 09:14 PM
billmerbach's Avatar
major noob
Where you located I can set you up with just about everything you need to build a fresh 350
Old June 11th, 2014 | 08:38 PM
oldrelics's Avatar
Nobodies done a swap?
Old June 11th, 2014 | 11:25 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I've done it on a 64 88. Just used a big piece of C channel iron for a crossmember and drilled new holes in the frame. I remember the slimjim yoke fitting the th400, but don't remember what we did for a driveshaft. We had a pile of 20 of them out back, and probably just used conversion u joints on something "close enough". It was probably 7 years ago, so i'm a little fuzzy on it. I also remember making custom engine mounts for the frame with the welder. The th350 is going to be really short. I believe we used a th400 with a 9" tailshaft.
Old June 12th, 2014 | 01:53 AM
oldrelics's Avatar
Do you remember what manifolds/headers were used?
Old June 12th, 2014 | 07:34 AM
I believe they were from an olds 403. The type that the crossover pipe drops down in front of the starter solenoid with the crossover pipe under the pan.
Old June 12th, 2014 | 07:36 AM
not the 60's full sized manifolds with the center dump. The crossover pipe was too short, so we ran dual exhaust from each manifold, and made a block off plate for the crossover hole on the passenger side.
Old June 12th, 2014 | 09:20 AM
kjr442's Avatar
Kjr442
I didn't do the work on mine, but it has a 455 in it. I assume it has the long trans. if you need me to take any pictures of mounting, or whatever let me know.
Old June 12th, 2014 | 09:35 AM
oldrelics's Avatar
I am talking SBC 350, not an olds 350, sorry guys.
Old June 12th, 2014 | 09:38 AM
major noob
Old June 12th, 2014 | 09:53 AM
70cutty's Avatar
Beer Connoisseur
You are probably gonna need something like sanderson cast iron headers or shorty header for a camaro.
Old June 12th, 2014 | 09:55 AM
hookem horns's Avatar
How bad off is the 394? Might end up cheaper/easier to freshen it up and get an adapter to the transmisson of your choice.
http://transmissionadapters.com/Olds_install.htm
Old June 12th, 2014 | 01:51 PM
oldrelics's Avatar
The 394 seems fine, 125 psi cold/dry compression test. Has a slight tick, tickier on first start up.
I love SBC, on stand in garage, beggin for a chance to make the olds rock.
Adapter? $1000! no way.
Old June 12th, 2014 | 08:09 PM
Mark71
November 8th, 2023 08:44 AM
glendalegearhead
July 6th, 2015 12:25 AM
sx455raidercelticfan
August 1st, 2010 09:03 PM
moparmusclecars
September 3rd, 2008 07:15 PM
Retrorocket88
March 1st, 2007 07:22 AM
