455 Olds engine swap into 56' Olds
Old Feb 18, 2007 | 08:05 AM
Retrorocket88's Avatar
Does anyone know how difficult it would be to swap a 455/400 combo into a 56' Olds? I am considering installing a more modern set up in my 56'Olds. The car is a basket case, so I'm not cutting up a "good" car.
Old Feb 18, 2007 | 12:50 PM
2blu442's Avatar
455 in Vintage Olds
Here's something to consider then.... about 20 years ago I bought some sheetmetal from a 1970 Vista Cruiser wagon. The owner had stripped the body off the frame and put about a 1956 Buick 2 door body on it. He claimed that all he needed to do was build body mounts to match the frame. That the wheelbase and width was just right, that the steering column even came through at the right angle to work with the dash. So at a glance, he had a nice old Buick but with late model drivetrain, steering and brakes. If you have the time to do a little research this could be an easy way to make a fun street rod. John
Old Feb 22, 2007 | 07:42 AM
hurricane's Avatar
i got a 455 in my 57 and a R400 TRANS NO PROBLEM go for it if you can't yous ypu cross member you can fab one here is a pic of my 57olds009.jpg
Old Feb 22, 2007 | 05:40 PM
How hard was it to do? Someone told me the engine mounts on the frame are in the same location of a 455. What about a cross member for the trans? Do I use one from a newer car?
Old Feb 28, 2007 | 07:01 PM
64Rocket's Avatar
Hello
when I put a '70 OLDS 350 in my '50 OLDS coupe, I used a universal engine mount from J.C. Whitney. It is tubular and banana shape. I used the stock rubber mounts for the '70 350. The mount used the stock thru bolt for the rubber mount. I also made a trans mount out of 2" channel and welded tabs on each end. Moved the engine as close to the firewall as possible, cut the brkts and leveled the engine and drilled and bolted in everything.
Gene
Old Mar 1, 2007 | 05:15 AM
Sweet! Thanks Gene! Nice car by the way!
Old Mar 1, 2007 | 06:22 AM
Oldsguy's Avatar
Past Administrator
Gene, nice looking car!
Don't know about the mid fifties, I know that after '49 with the introduction of the V-8 things changed but on my '48 (orginally straight six) the engine mounted to the frame off the front. So when I put a 455 in the '48 I will have to fab a cross support like you mentioned. Didn't know J.C. Whitney sold them. Cool, I check into that.
autofluencia
Jul 24, 2015 05:49 PM
88olds350
Jun 25, 2013 06:47 PM
MLK-442
Oct 28, 2011 04:26 PM
italian ice
Sep 23, 2010 03:31 PM
moparmusclecars
Sep 3, 2008 06:15 PM
