Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Budget friendly exhaust
Old Sep 26, 2025 | 11:45 AM
DewChugr's Avatar
Photoshop God
I have a 71, ls and flowmaster headers. What have you used for exhaust that doesn't break the bank?
Old Sep 26, 2025 | 02:06 PM
I would check out some local exhaust shops that can fabricate a 2.5 inch system. I use aluminized pipe, pick the muffler of your choice based on the sound you're after.
Old Sep 26, 2025 | 02:53 PM
^^^THIS^^^
If you wanted to go really cheap you could buy shorty glasspacks and put turn downs on them before the rear axle. That would be loud as hell though. Same thing a friend of mine had on his 81 Camaro when we were in high school.
Old Sep 26, 2025 | 02:55 PM
Originally Posted by Olds64
^^^THIS^^^
I did that in the 90s with regular Midas mufflers and it was obnoxiously loud.
Old Sep 26, 2025 | 04:18 PM
I did same on my '67 4-4-2 in 1969. One of the dumbest things I did.
Old Sep 26, 2025 | 06:34 PM
Loaded68W34's Avatar
If you have a mig welder and a cut-off wheel, buy a kit like this and make you own:
https://www.ebay.com/itm/35672483670...Bk9SR_aR9ouxZg
The above kit is $79 or you can find one with an X-pipe for a little more. A mig welder will weld stainless really well.
You can add some V-bands to make it easier to remove when needed:
https://www.ebay.com/itm/20469059661...3ABFBMyu-VjLFm
2.5 Inch V-Band Flange&Clamp Kit Male/Female With Ridge Exhaust Stainless 4 Pcs - Picture 1 of 7
The above V-bands are less than $40 for the set.
Buy a set of stainless mufflers of your choice and with a little time and effort you will have a nicer system than the standard exhaust shop "crimple-bend" system and probably save some money too.
I have made a few systems with kits like this so far. They work really well, but it does take time.
Old Sep 27, 2025 | 12:13 AM
If you were closer to Phoenix I could make you a deal you couldn’t refuse for a 2 1/4” header back system that is languishing in my garage.
asaputo
Site Help
17
Feb 14, 2024 05:38 AM
Jul 2, 2017 05:54 PM
dlmsavings1
Sep 3, 2013 09:01 AM
Joffroi
Jan 25, 2011 09:53 AM
Crazy88
Jul 15, 2009 05:39 PM
