Engine Block Petcocks 1959 Olds 98
Old Aug 26, 2020 | 12:41 PM
gkhashem's Avatar
Well working on the exhaust I noticed the block has a 90 degree petcock drain on both sides of the engine. What size is the petcock threads? I would rather get a spare before I try to remove this.
I see 1/4", 3/8" and others.
Any idea of the size? Maybe the same as the radiator?
Old Aug 30, 2020 | 06:38 PM
gkhashem's Avatar
Guess no one knows. Well seems like I got to figure it out myself as usual.
Old Aug 31, 2020 | 05:57 AM
I removed the block drains from the 6.9l IDI in my Ford F250 and installed petcocks I found at the hardware store. It's a PITA removing the existing drain plug or petcock and running to the hardware store, but that's a sure fire way to avoid getting the wrong part.
Old Sep 5, 2020 | 02:50 PM
gkhashem's Avatar
Petcocks opened easily and I easily drained the block and re-filled it. Coolant was actually real clean.
They look like 1/4" on the threaded side.
pdsap
Nov 1, 2016 06:31 PM
bspaulding
Sep 3, 2016 04:15 PM
Oldsragger
Apr 22, 2015 01:57 AM
Yukon
Nov 15, 2013 06:29 AM
Eaglewings
Sep 12, 2008 05:22 AM
