Engine Block Petcocks 1959 Olds 98
Well working on the exhaust I noticed the block has a 90 degree petcock drain on both sides of the engine. What size is the petcock threads? I would rather get a spare before I try to remove this.
I see 1/4", 3/8" and others.
Any idea of the size? Maybe the same as the radiator?
I removed the block drains from the 6.9l IDI in my Ford F250 and installed petcocks I found at the hardware store. It's a PITA removing the existing drain plug or petcock and running to the hardware store, but that's a sure fire way to avoid getting the wrong part.
