No electronics working in car
Old August 10th, 2018, 06:09 AM
cr1114's Avatar
Hello everyone i have a 1966 olds 98 that starts and runs but i have lost all electrical power to the car. Any suggestions on what it could be? Thanks
cr1114 is offline
Old August 10th, 2018, 06:59 AM
If you had really lost ALL electrical power, it wouldn't even start, so there is partial loss somewhere. You need to carefully test circuits one-by-one and figure out exactly what works and what doesn't.
joe_padavano is offline
Old August 10th, 2018, 09:18 AM
Before getting out your DVOM make sure you check the fuses.
Olds64 is offline
Old August 10th, 2018, 10:58 AM
Luther99's Avatar
Sounds like you might have a break in the wiring coming from the junction box from the battery , if you have no power to the rest of the car
Luther99 is offline
Old August 10th, 2018, 12:58 PM
Do all the outside lights work including headlights?
If you talking about the power stud on the horn relay, that's not it as the car runs. There is only one wire that goes into the car. Then it runs to a splice that branches out to feed three fuses, (the tail lights, courtesy lights, and stop lights), another branch feeds the ignition switch, and another feeds the headlight switch.
oldcutlass is online now
Old August 10th, 2018, 01:50 PM
........... i have lost all electrical power to the car......
Define this more clearly. It will help people understand your problem. Word your reply carefully so it "paints a picture' for the reader.
Allan R is offline
extreme_442
October 1st, 2019 06:32 PM
JackBronson
August 10th, 2019 04:07 AM
roosgunboss
April 10th, 2019 06:13 PM
77ricbaez
August 6th, 2016 04:42 PM
shamusj
June 13th, 2013 07:48 AM
Quick Reply: No electronics working in car
