Need to get my power windows down (hot wire?)
Old Jun 13, 2013 | 12:21 AM
shamusj's Avatar
Hi Guys,
I'm a bit of an electrical idiot yet have not melted anything in years.
I have a '68 442 with power windows...car is trashed, harness is a bit of a mess. Is there a way I can apply power directly to the power windows so I can roll down all the windows? I have the switches and the PW harness seems to be in tact. The under hood harness has been screwed over here and there.
any ideas would be appreciated.
Old Jun 13, 2013 | 03:58 AM
If you are apprehensive about connecting your harness to power, then you can power up the P/W circuit breaker on the firewall near the brake booster.
Old Jun 13, 2013 | 06:14 AM
shamusj's Avatar
Thanks Eric.
Now for the really dumb question- what is the best way to power up the PW harness solo?
Can I simply take car battery and run clips directly to pw wire and then ground to frame? I've made some interesting electrical blunders in the past...just making sure this wont be another one.
Thanks again for the help.
Old Jun 13, 2013 | 06:37 AM
Take the wire off of the hot side of the circuit breaker.
Connect the positive battery terminal to the terminal of the circuit breaker with a fairly heavy wire (at least 12ga).
Connecti the negative battery terminal to a good ground.
The windows or the top should work.
( I recall that the full size cars had a relay to switch on the widows only with the ignition on, but I don't recall where in the circuit it was located).
Old Jun 13, 2013 | 07:48 AM
Majic Jack's Avatar
power for power windows
Use the battery from a cordless tool. That is how we get the window down in the doors we purchase at the bone yard.
Smitty's72
Jan 23, 2013 09:20 PM
Dpc2
Oct 17, 2012 12:23 PM
socalrs
Aug 14, 2012 11:07 AM
squirell
Apr 13, 2011 05:22 PM
rustycarr
Mar 7, 2007 06:24 AM
