Power window wire route for rear windows
Old Jan 23, 2013 | 06:40 PM
Smitty's72's Avatar
I am adding power windows to my 72 Cutlass. I am trying to determine where to run the wires, drill hole for gromet and fasten the screw tabs. I have found a couple dimples, but I would like a reference. I would appreciate any help.
Old Jan 23, 2013 | 07:22 PM
oldsconv's Avatar
I just did mine and can help - pm me, but...... Check out a very thorough article at www.buickperformanceclub.com/PW.htm
Only major difference, on some cars you wire main power to fuse box like article says and others like my 70 Cutlass go through a breaker on firewall and then to horn relay for main power. So, look at your harness at firewall as it may be different than what is discussed in article.
Old Jan 23, 2013 | 07:44 PM
rcorrigan5's Avatar
Randy C.
Attached are a few pictures of the power window wire run on the driver side rear of my '69 4-4-2 convertible. Don't know if it's the same or similar but I've got the pictures on file so I thought I would throw them out for a look-see.
Randy C.
Old Jan 23, 2013 | 08:47 PM
Lady72nRob71's Avatar
See if these might help...
https://classicoldsmobile.com/forums...html#post55206
Old Jan 23, 2013 | 09:09 PM
Smitty's72's Avatar
Randy, Your pics were just what I was looking for. Thanks everyone! I will check out your links also. Mike
Old Jan 23, 2013 | 09:20 PM
Smitty's72's Avatar
Oldsconv, That article is perfect. Thanks again!
jaybone
Apr 15, 2015 06:52 PM
shamusj
Jun 13, 2013 07:48 AM
squirell
Apr 13, 2011 05:22 PM
Flye
Sep 27, 2009 12:42 PM
rustycarr
Mar 7, 2007 06:24 AM
