which oil for the original airfilter in my 98 /1953 ?
Old June 4th, 2016, 02:37 AM
stocki26's Avatar
please can anyone tell me which specification of oil you would recommend to put into the airfilter here in Austria ?
I am driving the olds just in summer, from 20°C to 35°C can happen usually
stocki26 is offline
Old June 4th, 2016, 03:53 AM
Doesn't matter, so long as the viscosity is roughly correct.
If I recall, most oil-bath air cleaners want 30 weight oil (it should say on the label or in the owner's manual), so anything around 10W30 should be fine.
Just buy the cheapest one you can find.
MDchanic is offline
Old June 4th, 2016, 08:07 AM
Proud Viet Nam Veteran
redoldsman's Avatar
I hate those old oil bath air cleaners. I put a dry element in my 54. Nobody can see it and it is a lot cleaner. It was a Wix filter #42088.
redoldsman is offline
Old June 4th, 2016, 05:53 PM
Rocketowner's Avatar
I don't think it would matter. I changed mine and had some 30W non detergent on the shelf,and it was fine. Larry
Rocketowner is offline
Old June 4th, 2016, 10:28 PM
Ozzie's Avatar
I don't have the shop manual for the 1953. The 1955 shop manual says that there were two air cleaners, a "standard" and a "heavy duty (oil bath)". In my life, I only remember seeing the oil bath. It's service calls for clean & replenish with 1 pint of SAE 40 oil. The standard cleaner calls for clean & re-oil with engine oil.
Since the oil in the oil bath cleaner is there to "catch" the crud when it attempts to make a U-turn, probably the oil is not as crucial as its level is. I usually use SAE 30 or 40 non-detergent, but almost any oil should work.
Ozzie is offline
Old June 5th, 2016, 02:46 AM
Frank Ignachuck
ignachuck's Avatar
I use SAE30 in mine. As MDchanic noted, get the cheapest you can find.
ignachuck is offline
Old June 5th, 2016, 11:38 AM
stocki26's Avatar
thank you all very much !
stocki26 is offline
Old June 8th, 2016, 10:34 AM
Tedd Thompson's Avatar
If mine (and I have one) I would change it over to a dry paper filter like what I and Redoldsman did and not worry about it for 8000 miles. It is a easy conversion and not visable unless you take off the air cleaner top..... Tedd
Tedd Thompson is offline
JPMDaddy
January 14th, 2019 08:41 PM
rustycragars
December 25th, 2016 06:06 PM
ozzyolds
June 2nd, 2008 01:58 PM
thomaswatk
March 22nd, 2007 01:31 PM
Quick Reply: which oil for the original airfilter in my 98 /1953 ?
