Turn signal switch assembly
Old May 18, 2011 | 02:15 PM
fmbjogger's Avatar
I'm having a tough time finding a replacement for this unit ( pictured). Can anyone locate one or provide a part # to help with search ? Thank you.
Old May 18, 2011 | 03:27 PM
jensenracing77's Avatar
what year and model is it for? does it have tilt or telescopic wheel? does your car have cornering lights? i think all this matters for the application.
Old May 18, 2011 | 03:34 PM
fmbjogger's Avatar
Sorry Jensen, it sure would help with that info: '67 98 with tilt/telescoping and no cornering lamps.
Old May 18, 2011 | 11:04 PM
oldsonharmont's Avatar
Did you check NAPA yet, they had the switch and harness for my '71 Cutlass.
Old May 28, 2011 | 03:26 PM
Rex's Avatar
Rex
Just went through that drill and ended up buying a used column, which by the way aren’t easy to find either, to salvage the turn signal switch for my 68-98. You can buy the turn signal cam (that white piece on your switch) from several places on ebay motors. I spent weeks looking for the whole turn signal switch and there are none to be found for a tilt-tele column. Good luck on your search
Old May 30, 2011 | 04:22 PM
66ninetyeightls's Avatar
Land Yacht Captain
I found a repro switch for my 66 98 LS here. It worked great.
http://www.shee-mar.com
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
martine
Jan 22, 2009 01:13 PM
ewingr
Nov 14, 2007 09:18 PM
