Transmission Rebuild Recommendations
Old Feb 22, 2024 | 08:49 AM
Bigsk8r's Avatar
So after 53 years, the TH400 in the old girl has given out. As I do not yet have a large garage, cherry picker, or engine stand, I will need to locate a shop to do the work. Although it will be costly, I am thinking to have the following done and would appreciate any recommendations:
- Pull engine and transmission
- Rebuild transmission
- Replace pan gasket, rear main seal, and any other seals that are easily accessible with the engine out.
- Replace motor and transmission mounts
As a potential item that is easier now than later... get the left side dual exhaust manifold and go ahead with new, stainless dual exhasut. May not make that expense yet though...
Thanks!
Old Feb 22, 2024 | 08:57 AM
Sounds like a good plan. Where are you located?
You mentioned stainless exhaust, you won't be able to buy any kits for your car the way guys do for their Cutlass. I suggest you take the car to a local exhaust shop once the engine and transmission work is done and see what they can do. You can get exhaust manifolds out without lifting the engine. It's a PITA though.
Old Feb 22, 2024 | 09:05 AM
Bigsk8r's Avatar
Located in Austin area of Texas. Live in a Northern suburb called Leander. Asking around now for local recommendations.
Fortunately, when the blowout of the dipstick happend, my son limped it straight to my place and parked it in the cul-de-sac in front of our house. So, getting a tow truck to it, and getting it to a shop once one is selected will be the easy part.
Old Feb 22, 2024 | 05:26 PM
307-5a's Avatar
Roy Ale
I keep blowing out frost plugs , so could change all frost plugs and when transmission has been disconnected from engine , look for a frost plug at back of engine . There is one frost plug i did not change yet , it is too close to the dip stick tube , i could not get the dipstick tube out without breaking it so i still have at least one rusty frost plug that i can see .
Shawnk111
Dec 22, 2020 08:54 AM
Vintage Chief
Jan 19, 2019 06:52 AM
dalilama
Jun 30, 2016 11:37 AM
dmruschell
Jul 21, 2015 03:42 PM
wolfman98
Oct 27, 2009 07:37 AM
