Owner of a 1968 98 convt
Old Aug 9, 2020 | 05:15 AM
dukeomer's Avatar
I just purchased of ebay a 1968 98 convertible red in color (I believe they call it Scarlet) with white interior (parchment).
Old Aug 9, 2020 | 05:58 AM
83Delta88's Avatar
Pictures! When you can.
what else do you know about the history of the car?
Old Aug 21, 2020 | 07:27 AM
dukeomer's Avatar
Where is the coolant sensing unit
My 1968 Olds 98 convertible was finally delivered by the transport company last Monday. I had some coolant issues. The bottom hose pipe busted. Replaced both the top and the bottom hose. It seems the thermostat needs to be replaced as well as the coolant sensing unit. Can someone tell me where the coolant sensing unit is located on the 455-4BBL engine? Thanks
Old Aug 21, 2020 | 07:34 AM
The thermostat is in the thermostat housing in the front of the engine connected to the upper radiator hose. The coolant temperature sensor is threaded into the intake manifold coolant jacket next to the thermostat housing.
Post pics of your Olds, stat!
Old Aug 21, 2020 | 07:59 AM
dukeomer's Avatar
Pictures of my 1968 98 convt.
I will be the third owner
Paint is in great condition.
Gorgeous interior
I was told the mileage is genuine
The Olds being loaded into the transporter
The Olds being unloaded from the transporter in Houston
Old Aug 21, 2020 | 09:03 AM
Sugar Bear's Avatar
Absolutely BEAUTIFUL!!!
Up that speed alert to an even 100, that's where it will start to smooth out😎
Best of luck!!!
dukeomer
Aug 11, 2020 04:06 AM
shiftbyear
Jul 19, 2018 03:12 AM
55 2nd series
Ninety-Eight
Oct 28, 2014 01:00 PM
The Tin Man
Aug 5, 2011 05:40 AM
Uncle Hulka
Ninety-Eight
Jun 20, 2008 08:50 AM
