Replacing instrument panel bulbs
Old Aug 21, 2020 | 09:55 AM
dukeomer's Avatar
On my 1968 Olds 98 convertible, the instrument panel bulb for the auto transmission shifter position needs to be replaced. Do I have to remove the instrument panel to do that. Any help would be appreciated.
Old Aug 21, 2020 | 01:03 PM
Most bulbs on that vintage can be reached from behind, provided there isn't something in the way. I think you may have more luck lowering the steering column than removing the dash, as the gear indicator is above the column and below the speedo. Typically, there is a piece of trim below the column, that comes off. Then, you have 4 or so bolts holding the column up, but, be careful, there is a little cable that pulls the gear indicator that is bolted onto a track on the rotating part of the column. Be sure to disconnect that first, and be sure to mark where it goes and put it back in the same spot when done.
Then lower column so wheel sits on front seat. You should then be able to reach back side of gear indicator.
I do not own this year car, so I don't know precisely, but this theory should work. If you read the 68 chassis service and fisher body manual, you can see these things before tearing into it.
Old Aug 22, 2020 | 06:19 PM
455Dave's Avatar
Hi, welcome and great car! The bulb is on the right side of the indicator (passenger side). It’s not easy but you can get it out from underneath. It helps to let the column down (remove lover bezel and the mounting bolts under the dash. You might find the housing to be melted or distorted somewhat... causing the socket to not stay locked into the plastic PRNDL housing. Both of my 68s have this issue. I tried to give you an idea of location in the photos. I’m doing this on my iPhone so it’s not great but hopefully it helps you! Dave
v
Old Aug 25, 2020 | 02:15 PM
dukeomer's Avatar
Thanks Dave for the detailed info and the photos! I need to get a bit brave to start tackling these.
Mauch712
Jan 24, 2020 05:52 AM
dynamic63
Body work
Feb 8, 2019 12:24 PM
rroth01
Nov 10, 2014 07:20 AM
rroth01
Aug 25, 2014 06:40 AM
