Headlamp Switch
Old Aug 25, 2020 | 02:29 PM
dukeomer's Avatar
Headlamp Switch
On my 1968 Olds 98, when I pull on the headlamp switch ****
to the first position to turn on the parking/tail lamps, the **** comes loose in my hand. Then I have to pull on the switch rod to the first or second position. The **** is not a tight fit on the rod. Any suggestions?
Old Aug 25, 2020 | 02:45 PM
The rod is supposed to be pressed into the ****. You'll need to pull the rod completely out of the switch, use some plastic epoxy to secure it back in the ****, and try that. I suspect you'll ultimately need to replace it with a new one. I assume you know that you need to get under the dash and depress the lock button on the switch to release the rod from the switch, right? Pull the rod out to the headlights on position, then hold the button in and pull the rod out the rest of the way. You don't need to hold the button when putting it back in, however.
Old Aug 25, 2020 | 04:03 PM
dukeomer's Avatar
Joe thanks for your help. Is there any web site that I can browse to get the lamp **** and the rod. Are any new ones still available or would I be looking at used ones.
Old Aug 25, 2020 | 04:07 PM
I'm afraid good used is likely your only option. Any 1968 Delta 88 or Ninety Eight is the same. Good luck.
Toocool
May 31, 2019 04:47 PM
Christophe2m6
Oct 22, 2014 02:40 PM
wisniows
Jan 27, 2014 06:45 PM
Mak
Dec 29, 2012 04:46 PM
medri
Apr 29, 2012 05:33 PM
