Lefty tighty-righty loosey
Old Sep 24, 2024 | 11:15 AM
Mikeyt's Avatar
Mikeyt
Had a flat on the ds of my 62 and could only turn the lug nuts a small bit before they wouldn't go anymore.
So I tightened them a bit and tried again.
I noticed when I tightened them they turned easily. When I loosened them they got tighter.
so I tightened them all the way, got tire fixed and loosened the lug nuts back on and she's good to go. 😁
Old Sep 24, 2024 | 12:58 PM
rocketraider's Avatar
Oldsdruid
Olds finally ditched driver side LH threads in 1964. Chrysler stuck with that nonsense thru 1975.
Be glad you had a simple lug wrench. Tire shops have replaced countless lug studs and hubs because they went after LH thread nuts with an impact cranked wide open. They've also been known to replace a broken stud with a RH thread stud on the same wheel position. Imagine the havoc that created down the road.
Look for the "L" stamped into the end of the stud.
Old Sep 24, 2024 | 01:26 PM
Mikeyt's Avatar
Mikeyt
I did notice the "L" after I got them off.
It threw me off because I've had the right rear off and it was standard thread.
Old Sep 24, 2024 | 03:18 PM
Driver's side lugs (AND the spindle nut) are LH thread. Passenger side are RH thread.
And speaking of Chryslers, a friend of mine owned a 1970 AMX with 390. AMC used a Chrysler Dana 60 in that car. The Chrysler-sourced axle had LH lugs on the driver's side, but the AMC front hubs were RH thread on both. He had to buy two separate McGuard wheel lock kits, one for GM and one for Chrysler, to get three RH locks and one LH lock.
Old Sep 24, 2024 | 04:26 PM
Rallye469's Avatar
ah…I snapped more than one lug that way.
getmygoat
Wheels and Tires
Nov 6, 2024 09:04 AM
lshlsh2
Sep 21, 2023 11:59 PM
bluefire
Sep 7, 2016 05:03 PM
Eightbanger
Feb 26, 2016 04:21 PM
Kidcutty
Feb 26, 2010 06:55 PM
