1979 Ninety Eight Regency - Rear sail panel reading light
Old April 29th, 2023, 07:59 AM
jasesquire's Avatar
If you have seen my post in the "Newbies" Forum, you know I just acquired this pristine '79 Ninety Eight Regency, with just 2,600 miles.
Getting to know more about the car now. The rear sail panel reading lights were not working, so I removed them to find the passenger side just needed a bulb. However, the driver's side was totally missing, not just a bulb, but the entire socket. All I found was a bare wire sticking out. See photos. The first photo is the correct passenger side. The second photo is what I found when I removed the lens cover on the driver's side.
Any ideas to where to find the missing beige colored socket so I can attached the bare wire and then insert a new bulb? I am convinced the car left the factory with the missing bulb socket.
Many thanks!
jasesquire is offline
Old April 29th, 2023, 09:10 AM
Oldsdruid
rocketraider's Avatar
That wouldn't be unusual given GM quality control (or lack of it) in that era.
One thing I'd do ASAP until you get the socket is to tape the exposed end of that wire with electrical tape to prevent shorting it out against body structure metal.
The socket appears to be same as used in exterior side marker lamps. Try a NAPA or other reputable parts store. Show them the picture and see what they can find.
If no luck, I have a 76 Custom Cruiser wagon that's headed to the scrapyard. I've been salvaging exterior lighting plugs and sockets from it for my 76 Regency and it still has the rear marker sockets.
This is a case where you might need the FB manual. I'm not sure how the sailpanel lamps are mounted or what might have to be taken apart to access the lamp socket.
Here's two versions of this socket. You may need the right-angle version.
rocketraider is online now
Old April 30th, 2023, 06:55 PM
vintagepne's Avatar
That car looks brand new!
vintagepne is offline
Old May 1st, 2023, 04:00 PM
jasesquire's Avatar
Wow...fantastic information and photos. Local NAPA has these sockets in stock. But, you're right, the harder act is the installation...removal of the light itself will be part of the solution. Probably above my pay-grade, but at least it's a great start for my trusted mechanic.
Many thanks for post.
Old May 1st, 2023, 04:02 PM
jasesquire's Avatar
Thank you. With 2,600 miles, as you can see from the photos, it was perfectly stored and preserved. I am very fortunate to be the next care-taker. I have owner records and original documentation back to the original dealership and owner.
Old May 6th, 2023, 08:22 PM
Big Daddy No Bucks
ThePackRat's Avatar
That's one sharp ride ... think I saw it listed online in the past.
Some of the best colors one could have in the 77-79 cars too IMHO.
The 77-79 Ninety Eights are some of my favorites as most years have fender skirts ... which are something I always look at & want to permanently remove, which is more often than not impossible without getting into major reconstructive surgery.
Always found it interesting someone skipped over the fiber optic lamp monitors being it has the moonroof & cornering lamps.
A set of later locking wire wheels would look real nice on there as well (sorry small scanned crappy polaroid pic from the mid 1980's).
I wonder despite that cars low mileage & the fact it was well cared for ... if it suffered from the drooping headliner most did.
Perhaps the headliner & sail panels were re-done & someone man-handled the lamp socket on the one side & boogered it up.
ThePackRat is offline
Old May 15th, 2023, 06:32 AM
jasesquire's Avatar
Thanks for the kind words, PackRat. I'm way ahead of you regarding the wire wheel covers. I found an OEM set online, and they arrived last week. They really make the car look sharp. Headliner is perfect on top, with just a few loose areas on the sail panels surrounding the pesky reading lamps. I can live with it.
Old May 15th, 2023, 07:31 AM
Inquiring minds need to know! Post some more pics, NOW!
Olds64 is offline
Old May 15th, 2023, 08:35 AM
Oldsdruid
Wires?🤨 They make these cars look like a Florida retiree car.
To make a 77-79 Ninety Eight pop, you need these. The N82 chrome wheel option.
JVCCutlass
October 6th, 2023 05:40 PM
2blu442
August 9th, 2022 09:53 AM
brucegroesbeck
July 19th, 2019 10:36 PM
Machwest
December 26th, 2013 10:45 PM
sammy
February 25th, 2012 11:21 AM
Quick Reply: 1979 Ninety Eight Regency - Rear sail panel reading light
