1982 Olds 98
Old Dec 26, 2013 | 09:02 PM
Machwest's Avatar
1982 Olds 98
I noticed in nearly all my lights on my 1982 Olds 98 Regency Brougham there is like an optic fibre wire going to a very small clear lens in nearly every light. Is this for the alarm or what? Does anyone know what it is related too. Cheers Mike
Old Dec 26, 2013 | 10:01 PM
ThePackRat's Avatar
Big Daddy No Bucks
Exterior or interior ?.
There was a fiber optic lamp monitor option for the front & rear exterior lamps.
(these would be on top of the front fenders & above the rear window)
There was also an illuminated entry option available that used fiber optic tubes to illuminate the front door locks.
(carried light from the courtesy lamps on the lower part of the interior door panels I believe).
Another option on some years, was a lighted thermometer on the drivers exterior mirror.
(I believe that was fed from an illumination source somewhere in the instrument panel)
I don't believe there were any other fiber optic feeds for anything else in the 88/98 instrument panel itself ... I believe everything else was illuminated at night directly via bulbs.
Old Dec 26, 2013 | 10:40 PM
Machwest's Avatar
In the rear taillights the wire comes from the wiring harness and then into a plug on rear of tail light it has like a brass fitting on the end of it, not a globe, it is the same to the rear & front side lights
Old Dec 26, 2013 | 10:45 PM
ThePackRat's Avatar
Big Daddy No Bucks
Those are the fiber optic lamp monitor option.
The rears run to the center of the trim just above the inside rear window.
The fronts run from the high beams - the low beams & the parking/turn lamps to the small units mounted on the tops of the front fenders.
None of these are visible at night ?.
2wheeler
Jan 12, 2012 10:25 AM
82olds88rayale
Oct 12, 2009 07:57 PM
nitinnelapudi
Sep 28, 2008 01:01 AM
71rocket
Dec 13, 2007 12:54 PM
PITJIM35
May 29, 2007 12:27 PM
