1982 Olds Tornado
Old May 3, 2008 | 02:23 AM
nitinnelapudi's Avatar
1982 Olds Tornado
I have a Olds Tornado, that has an olds 307 5.0. I want to to slap that in my cad eldorado with ht4100. can this be done? i wan to use all the parts from the torn' and put them in the eldo'.
Old May 3, 2008 | 08:11 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I would think you could make it work. The caddy computer might make the Olds motor run a little hot, but it should work assuming they are both 82 ish cars.
Old Sep 25, 2008 | 09:22 AM
sosuzguy's Avatar
Yes this can be done. Here is a website where he tells you how to do it but he uses an olds 350 or 403...pretty much looks the same as the 307
http://www.radar58.com/eldo/swap.html
Old Sep 25, 2008 | 11:03 PM
geckonz08's Avatar
you can make it work --like anything I guess but I would look for using a 350 /400/403 /425.
The 307 is hell reliable but for performance I think you will be disappointed --that is unless you do quite a bit of work to on the engine to eek out some HP
Myself I am working through a 66 toro 425,th400 to install in my fleetwood --the 307 is coming out .
Whatever, good u r going OLDS
MIKE
Old Sep 28, 2008 | 01:01 AM
geckonz08's Avatar
then again --here is a series of 307 upgrade options
http://tlentz.oldsgmail.com/more_power.html
68oldsguy
May 5, 2015 04:41 PM
blwilliams
Mar 20, 2015 11:03 PM
malone-ren-con@att.net
Nov 22, 2014 11:30 AM
Robs picks
Oct 20, 2014 06:52 AM
hamm36
May 22, 2012 07:32 PM
