1970 convertible chattering dash
Old Jul 29, 2010 | 06:57 AM
1970conv98's Avatar
Hi guys,
My '70 convertible dashboard makes quite a squeaky, chattering noise when going over mild bumps or rough pavement.
Is there something that can be done?
Thanks,
John
Old Jul 29, 2010 | 07:15 AM
Lady72nRob71's Avatar
Two common issues...
Make sure the radio is supported from the rear. Most aftermarket installers ignore this. A bracket can be fabbed if there is no support.
Also, the air duct to the center A/C vent often gets loose in A-body models, as the foam pad between it and the ash tray deteriorates. Not sure if your model has a similar setup.
Make sure the A/C box parts are secure and all screws are there and secure. The main plenum was sealed with 2 screws and foam tape in A-bodies and it comes loose over age.
Lastly, check for other loose stuff when under there, to see if a PO crammed extra junk up in there...
Old Jul 30, 2010 | 02:46 AM
Yellowstatue's Avatar
Rob- The tank in the picture looks like a land yacht to me...
Old Jul 30, 2010 | 05:18 AM
Yep, just passing on ideas on similar things to look for.
Old Jul 30, 2010 | 05:47 AM
rocketraider's Avatar
Oldsdruid
Does it make the noise with top up and securely latched, or all the time? Top frame is part of structural rigidity on these cars, so if it only does it with the top down, I'd chalk it up to age.
After 40 years I'd say the old girl is entitled to a few squeaks and rattles!
Other than the stuff Rob and Yellow mentioned, you're probably gonna get into some disassembly to find what's squeaking.
Old Aug 3, 2010 | 06:16 PM
1970conv98's Avatar
Yes, it chatters with the top up or down. I thought possibly there was a set of bolts where a person could tighten the dash where it meets the firewall.
Old Aug 4, 2010 | 04:50 AM
Some cars could benefit from a light smear of grease on the hood bumper near the windshield. Not sure if your car has this, but would be worth a try. The 80's G bodies had this issue a lot.
Surprisingly, my vert has less sqeaks with the top down.
You can sometimes drum the dash lightly with your fist to track down some bigger rattles.
HitTheHole
Jul 29, 2013 09:39 PM
yeahbuddy
Mar 19, 2012 05:18 PM
Bryan59EC
Jun 3, 2010 10:36 AM
floater98
May 27, 2010 03:45 AM
DJMatthews
Dec 12, 2006 06:36 AM
