1968 Olds 98 AC with R12 freon
Old Jun 27, 2023 | 03:25 PM
dukeomer's Avatar
My 1968 Olds 98 still has the R12 freon system. It was charged last Aug 22 with R12. There seems to be a leak in the system. Is it possible to check where the leak is and then charge it again with the R12. The mechanic had charged me $70 for 1 lb of this freon.
if I do want to convert the AC system to the R134, what all do I need to replace besides the Compressor and the Drier. I have attached pictures of the engine bay
Old Jun 27, 2023 | 04:18 PM
Funkwagon455's Avatar
Recover, charge the system with air (preferably nitrogen). Spray dish soap (dawn) on all connections. Leaks are evident by bubbling. Make necessary repairs and recharge. If no leaks are detected, it can be the carbon seal on the compressor itself. Stick with the R12, lower operating pressure, and when properly functioning will throw pop cycles at you in Pheonix in August regardless of airflow on the condenser. I wish that I could “upgrade” my 134 vehicles to R12.😅. My hour long ride home today in Ft Worth traffic was chilly whilst the OAT read 107 degrees. Check your local FB or Craigslist for R12 cans for future use.
Old Jun 27, 2023 | 08:03 PM
Sugar Bear's Avatar
^^^Precisely°°°
Old Jun 27, 2023 | 10:16 PM
dukeomer's Avatar
How easy is it to get R12 freon?
Old Jun 28, 2023 | 02:34 AM
Don't waste your money and convert an R12 system to R134a. It won't cool efficiently. If you don't want to pay the price for R12 go to an aftermarket system like Vintage Air.
Old Jun 28, 2023 | 06:55 AM
Oldsfan's Avatar
Unfortunately, not may places have the equipment to recover refrigerant from an R12 system. When charging the R12 system in my '62 Starfire, I have a hard time finding a tech with a functioning set of R12 gauges. I keep fluorescent dye in my system to help spot leaks.
Old Jun 28, 2023 | 07:28 AM
Sugar Bear's Avatar
Hopefully in TX someone has the proper AC equipment reasonably close. We still have an old school shop in central NJ, AZ radiator. They're third gen cooling guys who do pretty much everything and do it very well.
That engine bay looks really nice, please post some pics of the car if you would.
Old Jun 28, 2023 | 07:34 AM
dukeomer's Avatar
Will they sell me the cans of R12 if I purchase it on EBID or EBAY, or do I need to have an EPA license to buy it on line
Old Jun 28, 2023 | 07:36 AM
dukeomer's Avatar
Car pictures
Car displayed at the Houston Autorama last Nov
Old Jun 28, 2023 | 07:42 AM
Sugar Bear's Avatar
Very nice ! ! !
Old Jun 28, 2023 | 07:57 AM
Beautiful!
If you have the system recharged with R12 just let the shop provide it. They may upcharge you a little bit for the refrigerant, but the only other option is buying a set of R12 gauges, a vacuum pump and doing it all yourself.
BTW, did you get those wheels from TrueSpoke? They are bad@$$!
Old Jun 28, 2023 | 08:01 AM
dukeomer's Avatar
Those wheels are from TrueSpoke. I ordered them in Aug 2021 and they shipped it in March 2022.
I did find a guy on EBid that sells the cans and he says he is local and can also charge it for me. I am in contact with him
Old Jun 28, 2023 | 09:59 PM
R12 in an R12 system. Well worth the trouble for the expense. I took this photo today. Please note the OAT and digital duct temperature.
Old Jun 29, 2023 | 03:45 AM
Tri-Carb's Avatar
Craigslist for the best deals on R 12.
Old Jun 29, 2023 | 04:32 AM
If you source R12 on Craigslist make sure you meet the seller at or near a local police station. Also, be wary because an unscrupulous seller might fill their cans of R12 with R152a.
Old Jun 29, 2023 | 04:35 AM
gkhashem's Avatar
You need to be certified to get R12, but if you can or find someone who is, get it fixed so the system does not leak. You can keep it going 5 years or more without a recharge. One system I had with a 1991 Cadillac ran from 2012 to 2022 and was still blowing ice cubes never touched it. A 1966 Cadillac was fine until I needed to fix the compressor clutch. That was fine too. They all leak some, it just how much, eventually they all need at least a recharge. Also the value of the car drops in my opinion when you convert it. It will never work as well. Yes it works, but not as well.
Old Aug 6, 2023 | 12:29 PM
Del67Mont's Avatar
Have factory A/C on my 67 Delmont hardtop. I bought it about 6 years ago, and most of the A/C components were in the trunk, except for mounting brackets and the bolts. Got it replaced with new or rebuilt components, and changed to 134A. Within 3 years, system had given up the ghost. so much for change over to 134A. I questioned the shop that did the work, was told they only warrant for 12 months, and besides "it's an old car, you have to expect things to break" Spent $2 grand to get it all done, didn't know I would have to start replacing components after 3 years. Last time I utilized their services.
dukeomer
Ninety-Eight
Apr 16, 2023 09:43 AM
goatwgn
Jul 7, 2022 06:08 AM
deltsanddueces
Mar 23, 2021 01:31 PM
GCH
Oct 13, 2016 06:02 AM
1FSTLS1
Mar 4, 2008 06:45 AM
