1962 isnt getting gas to carb
Old Apr 1, 2007 | 07:42 PM
muttmeg's Avatar
A kid pointed out a rubber cap like piece that draws the gas into the carb, that is cracked what is this part called? He told me and I forgot.
Old Apr 2, 2007 | 06:05 AM
Oldsguy's Avatar
Past Administrator
Not sure what you mean. Is this on the carb? The fuel pump is located forward on the engine low, below the a/c compressor if you have a/c, the fuel pump draws the fuel from the tank and pumps it into the carb. I guess you could actually call it a fuel "sucker".
Old Apr 21, 2007 | 09:26 PM
muttmeg's Avatar
Unhappy stumped
The fuel pump is fine. The line was clogged from old gas but I think I have that cleared. There is a loop in the fuel line that comes up into the trunk. When I lift that loop, one end is open ended going nowhere. Maybe there was a rubber length that rotted off which extended into the tank? And the fuel filter seems to have fallen off. I cant find any replacement filters on line. I wish I had a picture or drawing that would help me with how this is supposed to be working. Is there a chiltons or similar manual on this? I have a shop manual which has little to no reference to the fuel line, pump or filter other than the latter should be cleaned periodically.
Kate
SD72cutlass
Dec 7, 2014 04:47 PM
tds
Jul 1, 2014 12:51 PM
69CutlassAlex
May 28, 2014 10:19 AM
auto_editor
Jan 16, 2011 08:08 PM
