1972 W30 Manifold Question
Old Jun 9, 2015 | 02:24 PM
Se7enty5's Avatar
Boys: I'm having trouble with a couple of my manifold ports. I'm not sure what this port on my aluminum manifold is for? It's right beside the rad hose, passenger side. I have circled it in yellow. Any help would be greatly appreciated.
See attached.
Old Jun 9, 2015 | 04:06 PM
jozw30's Avatar
PCV elbow and valve run to carb.
Old Jun 9, 2015 | 05:28 PM
Se7enty5's Avatar
OK thanks a lot JozW30!! Does anyone have a photo of the setup? Still a little confused. Would it look like this?
See Attached.
Old Jun 9, 2015 | 05:38 PM
Mr Shifty Sidney's Avatar
These are from the Service Chassis Manual.
Don W
Old Jun 9, 2015 | 05:39 PM
The photo you posted is correct.
Don W
Old Jun 9, 2015 | 05:45 PM
lunaboy's Avatar
The Rocket Astronomer
not required port unless a 4 speed , I have a 1971 oem iron 4 speed intake with the
same port .
Old Jun 9, 2015 | 07:04 PM
Se7enty5's Avatar
Thx a whole lot boys, very helpful. Hopefully my mechanic and I can get this '72 back on the road ASAP. Stay posted
Btw, my Drivetrain is automatic 350TH. Any other confirmation on blocking off this Port if auto trans? Thx!
Old Jun 9, 2015 | 07:16 PM
All 72 W-30s had the hose routed as the picture you posted, regardless of trans.
A non W-30 442 with manual trans would also have it routed the same.
A non W-30 442 with an automatic would not have it routed this was.
Don W
Old Jun 10, 2015 | 09:04 AM
Welcome. The PCV port in the intake provides a port into the crankcase volume, and is the same as the grommets in the valve cover for functionality. It has nothing to do with the AT/MT question. Olds used this on W-30 motors and 4spd motors that had the dual ventilation PCV system where both valve covers had fresh air tubes to the air cleaner and the PCV valve was mounted to this port. This had more to do with the cam used in those engines than the transmission type.
I strongly suggest that you immediately get a factory Chassis Service Manual and make sure your mechanic READS it. Good luck.
Old Jun 10, 2015 | 09:10 AM
Actually, I have to ask...
Why waste your money on a (presumably) repro W-30 intake? The TH350 tells us that the car isn't a real W-30, nor even a factory big block car and the W-30 intake provides no performance benefit over the cast iron intake (the runners are the same). A good aftermarket intake would be a better choice, and you won't have to plug that PCV port.
Old Jun 10, 2015 | 06:08 PM
Se7enty5's Avatar
Guys, thanks again for the great input. I will be using the PCV port, and linking it properly.
As for the manifold, it came on the engine when I bought the car. I did not buy an aftermarket carb and intake due to budget but may in the future. It's no secret that the car is not a W30 and I'm not in creation of a clone.
You guys have been more than helpful and I appreciate the help along the way.
Thanks again!
70-442-W30
Sep 2, 2024 11:47 PM
442mark
Sep 18, 2019 08:26 AM
Vader
Aug 25, 2014 12:53 PM
stlbluesbrother
Nov 5, 2012 06:10 PM
mdk442
Dec 3, 2006 06:01 PM
