just got a 1970 442
Old February 19th, 2014, 09:33 AM
cowboytim68's Avatar
just got a 1970 442
ineed help with some questions
decoded my body tag need to know what it all means
color 43
body style 87
time code says o6e co8
cowboytim68 is offline
Old February 19th, 2014, 10:40 AM
Diego's Avatar
You sure the color is 43? Maybe you meant 34?
And the VIN is 34487? That's a two-door "Holiday" hardtop.
And do you mean "trim code" or "time code?" Because the codes don't match the date build, if I am correct. I'm sure someone will chime in to correct me if I'm wrong.
Diego is offline
Old February 19th, 2014, 10:49 AM
ill try to put pic of it on here it says color 43 and time code 06e co8
Old February 19th, 2014, 10:55 AM
body plate
he it is
Old February 19th, 2014, 11:11 AM
Lansing built
1970cs's Avatar
ST70=1970
344=442
87=HOLIDAY COUPE
E=LINDEN NEW JERSEY ASSEMBLY PLANT
2449=BUILD SEQEUNCE FISHER BODY
TR930=BLACK BUCKETS
PNT48=SHERWOOD GREEN
B=BLACK
06=JUNE
E=5TH WEEK START OF FISHER BUILD
C08=? CANT READ MY OPTION LIST
Pat
1970cs is online now
Old February 19th, 2014, 11:15 AM
thanks alot can anyone id the C08
Old February 19th, 2014, 11:20 AM
so the B does that mean black stripes
Old February 19th, 2014, 11:21 AM
Diego's Avatar
Black top. Stripes are not specified but there is a default color choice, which I'd have to look up. Otherwise, you have license to make the stripes black, white, or gold as they all match the trim combo, unless someone had a morbid sense of humor and ordered red stripes.
Diego is offline
Old February 19th, 2014, 11:23 AM
Rocketbrian's Avatar
The letter after the paint code is for the vinyl roof or convertible top color.
B is for Black.
C08 is the option code for the Vinyl top.
Some plants indicated this option on the data tag and some did not.
Rocketbrian is offline
Old February 19th, 2014, 11:28 AM
allyolds68's Avatar
Vinyl Top Option
allyolds68 is offline
Old February 19th, 2014, 03:23 PM
thanks every one will it hurt the value if i made it a hard top and how do u know if it was a w-30
Old February 19th, 2014, 03:24 PM
Diego's Avatar
What do you mean, you made it a hardtop? It was built a hardtop by the factory.
We already know it's not a W-30 because it wasn't built in Lansing. Was it sold as a W-30 to you?
Diego is offline
Old February 19th, 2014, 03:40 PM
no wasnt sold as a w-30 just checking no w-30 was built any where but lansing?
Imeant instead off putting vinyl top back on it
Old February 19th, 2014, 03:49 PM
Diego's Avatar
All W-30s are from Lansing, but not all Lansing cars are W-30s.
A hardtop is a hardtop regardless whether it has vinyl or not. I don't think it'll hurt the value if you left it off, but generally speaking factory stock fulfills a car's potential value.
Diego is offline
Old February 19th, 2014, 03:55 PM
ok thanks would it mack it more vaulable if i made it a w-30
Old February 20th, 2014, 04:30 AM
Past Administrator
Oldsguy's Avatar
Tim, I just read your other thread and was going to welcome you in that one but thought to myself, maybe I already did so. I checked this thread and see that I haven't, so welcome to CO. Personally, I like the look of the 70, 71, and 72 body styles like yours without the vinyl top on them but it is a hard job removing all the glue and junk and then of course you probably have some body repair work to do before prep and paint. On the upside, you won't have to worry about rusting under the vinyl any longer.
Oldsguy is offline
Tedd Thompson
October 7th, 2014 07:59 AM
kansjfr
June 13th, 2014 08:20 PM
Sircajun
February 17th, 2014 06:17 AM
jensenracing77
January 10th, 2010 04:02 PM
matt68
September 3rd, 2009 05:10 PM
Quick Reply: just got a 1970 442
