442?
And yes, the auto bench seat is possible. You can can see "what all is possible" checking out the SPECS booklet available free of charge at Wild About Cars:
http://wildaboutcarsonline.com/cgi-b...aldisplayed=50
Wild About Cars. http://wildaboutcars.com. An information supersource, especially Oldsmobile. More Olds content than anywhere else on the internet and continuing to grow.
You'll find Chassis Service Manuals, Product Information Manuals (AKA Assembly Manuals), Inspector's Manuals, and other documents that will contain this and much much more.
Dealer Brochures, magazine ads and articles, and the Automotive History Preservation Society library growing daily.
Free to join, free to learn.
If the emblems say "Cutlass", it's not a 442. In any case, as noted above, the VIN is unique for a 442 in 1969, so there's no need to guess, just look at the VIN.
Thanks! The guy working on it said the VIN starts with 34467! It does not sound like the numbers match though. He had trouble reading the other number but it is not the same. Should have it back in a month or so. We'll see.
It would not be surprising if they do not match. The G-block 400 motor used in the 68-69 442s was not one of Oldsmobile's better designs and many have been replaced over the years, usually with a 455.
You guys still there?
I have a "casting number" but it is only 8 digits? I am thinking one digit missing.
It is matching up pretty close to Joe Padavano's suggestion above. Also the mechanic somehow confirmed the displacement is 6.6L 400 CID V8
The casting number for a 68-69 400 block will be 396026 G and is a raised number located on the "shelf" above the water pump. The VIN derivative is a stamped number and is located on a pad below the No. 1 spark plug and is nine characters long.
Casting number:
VIN Derivative:
We are still here! Years are minutes for many of us.😂 glad you still have the car.
