whats good
Old Aug 30, 2014 | 08:54 PM
richkidd24's Avatar
whats good
im tryin to get some info on my cutlass i just bought im tryin to find out if it is a 1969 w31 f85 club coupe can anyone help me with this
Old Aug 30, 2014 | 09:01 PM
johnnyjaws's Avatar
give us imfo vin tag # numbers
Old Aug 30, 2014 | 09:02 PM
richkidd24's Avatar
the vin is 332779m284752
Old Aug 30, 2014 | 09:34 PM
The vin will only confirm that it is an F85, the year, and where it was built. To know for sure that it is a W31, paperwork is needed, as all of the components that make it a W31 can be added. You may have W31 parts on the car, but factory documents are the only way to know for sure.
Old Aug 30, 2014 | 10:33 PM
z11375ss's Avatar
Senior Moment Member
I've made my own W-31 paperwork. In crayon. It's legit.
Old Aug 31, 2014 | 06:04 AM
Welcome to the site, we do like pictures.
Old Aug 31, 2014 | 08:26 AM
Welcome. The fact that you are asking if the car is a W-31 tells me that it almost certainly is not. You'd know a real W-31 from the price tag.
Old Aug 31, 2014 | 10:27 AM
drop top olds's Avatar
W-31 tell tale signs.
BIG balancer on the 350
no air conditioning
larger valves in the heads (only visible when heads removed)
Probably an anti spin rear
68 and 69 had special force air induction
bench or bucket seat
You mention yours is an F-85. I think the F-85's were more "basic" as in fewer options. Others more experience may chime in and correct any inaccuracies.
Old Aug 31, 2014 | 11:03 AM
dnmfranco's Avatar
and that will tell what other than if no M for Lansing thus ruling out W-31
there was no pertinent info put on the cowl tag or vin for that matter that to identify W cars in 69
Old Aug 31, 2014 | 11:09 AM
dnmfranco's Avatar
if you posted pics of engine compartment that would be the first step
fender wells w holes in them for the scoops
air cleaner w snorkles
obviously a four barrel motor (last digits of carb 9255)
1111930 dist
windshield wiper hose running across fire wall towards pass, side if hose is not there see if there is a factory hole above heater core
the obvious balancer
check the tranny all were offered in 69 but the turbo 400
It will be easier to negate that it is one than to prove it is real unfortunately w/o purchase order or window sticker
Old Aug 31, 2014 | 01:07 PM
More specifically, the balancer should look like this:
blunce
Nov 26, 2012 04:06 PM
ELECMAN
Jul 6, 2012 08:17 PM
62radarlove
Mar 12, 2012 05:09 PM
Charlie_brown
May 25, 2010 01:55 PM
80v8Cutlass
May 26, 2008 05:44 AM
