Whats a good oil for break in
Old May 25th, 2010, 11:04 AM
Charlie_brown's Avatar
I was reading on car craft and i saw they mentioned Rotella T 15w-40 having a high ZDDP content, so i'm leaning towards using this. But after searching i found it only had a little over 1200ppm zinc/phosphorus. Is this a sufficient amount of should i be using something else?
Charlie_brown is offline
Old May 25th, 2010, 01:50 PM
jensenracing77's Avatar
just make sure you have a good amount of cam lube on the lobes and an extra bottle of assembly lube in with the oil you use (i have a local shop that runs 2 bottles) and will be good. i would add another bottle at the first couple oil changes also. i am seeing many guys using Cam Shield on every oil change with flat tappet lifters. just use your favorite oil if this is what you do.
jensenracing77 is offline
Old May 25th, 2010, 01:55 PM
Mikes65's Avatar
I just purchased a crate motor and the only oil they recommend for break in is the Shell Rotella 15-40. The directions state that if any other oil is used you must add break in fluid.No additives necessary for the Rotella.
Mikes65 is offline
stanzaschance
July 27th, 2015 03:23 PM
scooter123
April 14th, 2013 08:41 AM
zodiacblueS
September 20th, 2011 05:23 PM
AZ442
September 23rd, 2009 07:16 PM
Quick Reply: Whats a good oil for break in
