Trying to join in
Old Sep 9, 2009 | 08:14 PM
geezergasser's Avatar
Trying to join in
Since I'm still denied access to drivetrain/differentials forum after a week of trying, here's my question. Does anyone know a p/n for 57 olds rear axle oil seal? This rear housing has 59/60 pontiac posi carrier with shortened axles. Lube is leaking past new style bearing/seal. Also,I'm using a synthetic gear oil. Too thin for seal? Thanks for listening.
Old Sep 9, 2009 | 09:50 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Contact John at rocketracingperformance.com
He runs 57-64 Dropout rears, and will be able to help.
Old Sep 9, 2009 | 09:56 PM
delmontcrusier's Avatar
67 heavy metal
I hope you get it figured out but also if you post four more messages you should be able to get into all the forums and post in them(that is unless the managment changed the rules ).Also welcome to the site great place for info as you can alreaddy see.
Old Sep 10, 2009 | 04:16 AM
Oldsguy's Avatar
Past Administrator
New members are new until their first post, then they are registered and can post without restriction. You should have PM'd someone for help. Welcome to CO.
Old Sep 10, 2009 | 07:43 AM
citcapp's Avatar
Talking Welcome to CO
Try http://www.rockauto.com/catalog/raframecatalog.php The seal is listed under Wheel. They have them in stock. Their mail order service is great. I have a 57 Olds and I need to do the same thing to get posi in my car. If you don't mind my asking who did you axles
Old Sep 10, 2009 | 08:49 PM
Thanks citcapp. It looks like Rock Auto has the right size seal. The seal I got from NAPA was too big and was destroyed during install. I had the axles shortened at a buddy's machine shop. He said it was ez and even chamfered the ends. You will need to remove about 3/16" so that bearing fits flush to end of housing. Good luck and thanks again.
Old Sep 12, 2009 | 09:31 PM
Old Sep 12, 2009 | 09:37 PM
Thanks J for info on rocketracingperformance. It turns out that they're only a couple axle greasings down the road from me.
tj78_
Oct 11, 2010 08:29 AM
omg_its_nickels
Jan 19, 2010 10:16 AM
derek nesdoly
Apr 7, 2009 07:07 AM
NYC_MANDINGO
May 5, 2008 06:52 AM
ezdoesit2117
May 4, 2006 09:17 AM
