timing gear
Old May 18, 2016 | 05:58 PM
Jodi Taylor's Avatar
timing gear
Hey guys. Can you please tell me if my 69 cutlass (350) rocket has a nylon timing gear?
Thanks so much!!
Old May 18, 2016 | 06:01 PM
Sugar Bear's Avatar
Yes, original gears had nylon coated teeth.
Old May 18, 2016 | 06:33 PM
Thanks so much for the quick reply. I don't know if it's been replaced or not but definitely need to check. I had no compression and one of the cylinders and the push rod was bent and the exhaust valve was open. I was told to check into my timing gear! The car has been in storage and hasn't been started in 6 years. Unfortunately I was told the story that isn't true so it's up to me to make this car right again. Thank you for all your help😁
Old May 19, 2016 | 09:11 AM
Tedd Thompson's Avatar
The timing gear failure would not cause a bent push rod or valve as this engine is a non interrupted type motor. Though the gear may be worn or even jumped a few teeth the valves won't (can't) reach the pistons tops. Bent valves and torn up pistons are common failure in the newer timing belt over head cam type engines. That's probably where your friend got his idea of a bad timing gear. Though the timing gear is worth a look at I think your problems are some where else..... Tedd
Old May 19, 2016 | 09:51 AM
Octania's Avatar
"Can you please tell me if my 69 cutlass (350) rocket has a nylon timing gear?"
Not any more, it doesn't
80_cutlass
Sep 1, 2018 05:55 AM
Cman7713
Drivetrain/Differentials
Mar 20, 2016 08:11 AM
drjr56
Sep 9, 2012 08:05 PM
442scotty
May 13, 2009 05:42 PM
smcurro
Feb 27, 2009 09:27 AM
