Return to rockets
Old Feb 5, 2022 | 05:54 AM
Mr. Rocket's Avatar
Return to rockets
Hello,
Just wanted to do a brief intro of myself. Chris McClure from Slippery Rock Pa. I just recently bought a 69 350 Rocket with a TH400 trans to begin a resto project. After a long 20 year bender on Mopar I just couldn't resist the idea of building an Olds mill for a later vehicle. I was sold at the #5 heads! Lol It's an original 54k mile untouched 2 barrel motor that spins freely. So I'm here to read and gather a few parts.
Old Feb 5, 2022 | 06:45 AM
Welcome. FYI, the original trans in that 69 would have been either a Jetaway two speed for an early car, or a TH350 for a car built later in the model year. The TH400 wasn't used behind the small block in the Cutlass line. Good luck with it.
Old Feb 5, 2022 | 09:53 AM
Welcome to the site, lets see it.
Old Feb 5, 2022 | 10:40 AM
RetroRanger's Avatar
72 Olds CS
So your starting w the engine and trans and then finding a car ? Any ideas for model?
welcome to CO
Old Feb 5, 2022 | 12:01 PM
Mr. Rocket's Avatar
Yeah I'm starting with a motor and trans. My plan is nothing spectacular. Just a stock bottom end with Mahle piston and ring pack. Big valves in the heads with basic porting. Low speed torque motor. Set it up in a '60-'66 Chevy C-10 '60s style mild custom hot rod. No offense to anyone here.
Old Feb 5, 2022 | 12:08 PM
Mr. Rocket's Avatar
$300 for the pair. I couldn't not bring it home
Old Feb 5, 2022 | 12:15 PM
VI Cutty's Avatar
Always good to see a Chevy being improved with the addition of some Rocket power :-D
Old Feb 5, 2022 | 12:21 PM
Mr. Rocket's Avatar
My thoughts exactly.
Old Feb 6, 2022 | 02:24 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Great use, I had two Olds powered trucks. I had a 78 1/2 ton with an Olds 307 then Olds 350. I then moved the Olds 350 which had 307 5A heads and a 204/214 cam to replace the knocking sbc 350, even kept the factory TBI in the 94 Z71 I bought off my in laws. It was a way better truck below 4000 rpm than any LS powered truck, same trans and gearing. I had a circulating block heater burn it to the ground. I have my eye out for a non rotten 88 to 95 and have an Olds motor for it as well. Welcome and good luck.
Old Feb 6, 2022 | 07:38 PM
Mr. Rocket's Avatar
Thank you! It'll take some time to sort out motor mounts for the earlier Chevy truck chassis.
Old Feb 7, 2022 | 03:18 PM
We just cheated and welded the B body frame mounts on the 78. For the 94 we used the sbc clam shell bottom with 403 second gen Trans Am mounts. My friend had a 65 with a sbc 350 transplanted and the 3 on the tree converted to the floor. He blew second gear twice. With the TH400 you can beat the heck out of it and no worries. It has been 30 years since looking under the hood. This style might work with regular Olds rubber mounts. I came across them on Ebay.
https://www.ebay.ca/itm/1-Pair-Engin...-127632-2357-0
Old Feb 8, 2022 | 07:34 AM
Mr. Rocket's Avatar
Thank you. I'll check them out
Firelt1622
Feb 6, 2021 06:09 PM
dave1978
Jan 9, 2021 07:13 AM
camshaw
Oct 12, 2016 07:22 PM
armycav0
May 14, 2014 07:17 PM
QS442
Nov 30, 2011 05:45 PM
