Newbie from Austin TX
Old Jul 4, 2014 | 11:20 AM
Miles64Cut's Avatar
Greetings,
I have used this forum as a guest since last November and always appreciate the wealth of knowledge and community insight. So I decided to join.
Current projects on my 64 cutlass are - replace Horn Relay (discovered phantom draw); figure out the fuel gauge pegging problem (already replaced sending unit and checked continuity at the unit end - checks out OK) - dash gauge still pegging past full.....
Stuff I have done since November when we got the car (we = my son and me - project car and his first auto...daily driver for school)
1 - brake system overhaul
2 - replaced fuel tank
3 - new shocks
4 - added cooling system expansion tank
Lots of fun - I look forward to learning more.
Best,
Dave
Old Jul 4, 2014 | 11:26 AM
Welcome aboard.
Cool that you're doing a father son restoration. Great bonding and learning experience for both of you.
Sounds like you have a bad ground on your fuel system. Check the ground from the tank to frame, and the ground at the dash. Bad grounds will usually give the symptoms you're describing.
Old Jul 4, 2014 | 11:31 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Welcome from another Texan. There are a bunch of us on here and I think at least two in Austin. Have you been to Franklin's BBQ? Post pictures of your car when you have time.
Old Jul 4, 2014 | 11:36 AM
tru-blue 442's Avatar
Old School Olds
Welcome from down the street
in Marble Falls.
Old Jul 4, 2014 | 11:42 AM
Miles64Cut's Avatar
Thanks Allan R and redoldsman
OK - Tank to Frame has continuity. And the wire that connects to the sending unit also checks out. I have a wiring diagram and found the gauge wire up under the dash - but it feeds into a harness and circuit board - and I am not sure how to check the ground at that end. Do I need to pull whole board out?
Thanks,
Dave
PS - yes - Franklin's is awesome if you can stand to wait in line for a few hours....
Old Jul 4, 2014 | 11:44 AM
Miles64Cut's Avatar
Nice to meet you - thanks,
d
Old Jul 4, 2014 | 12:46 PM
Texas69's Avatar
Howdy
Welcome from Drippin' Springs, west of Austin. Good luck on your project.
Old Jul 4, 2014 | 12:49 PM
Miles64Cut's Avatar
Thanks!
d
Old Jul 4, 2014 | 12:58 PM
drop top olds's Avatar
Welcome...Currently living on the south side of Austin, TX
Old Jul 4, 2014 | 02:16 PM
Aron Nance's Avatar
Welcome to CO, Dave! Great, Father/Son project, and a good lookin' one, at that! Lots of good folks down your way (Austin, SA, Bastrop). Every November all the Texas Olds Clubs show up in Fredericksburg for a great three day weekend. Will try and remember to post about September the dates/times/schedule/things to do, so hopefully y'all can join us! Sometime next Spring, the North Texas Olds Club will once again host our annual Zone Show, again in Granbury. A really great time, with oddles of Oldsmobile's to attract your attention! Again, Welcome!!!
Aron
Old Jul 4, 2014 | 02:42 PM
Miles64Cut's Avatar
Thanks Aron.
Keep us posted on the Fredericksburg weekend.
today - got the horn relay, and steering wheel contacts all sorted. Taking a break from the fuel guage..
Happy 4th y'all.
Dave
4rims
May 13, 2011 09:14 PM
macrover
Sep 22, 2010 12:19 PM
texasred
Apr 16, 2009 12:00 PM
jmt147
Oct 26, 2008 07:46 PM
