New here not to Oldsmobiles
Heya,
I am glad to have found this place for fellow Oldsmobile gear heads
I had a 68 Cutlass S for 12 years then got forced to sell it. I am a few weeks from getting another 68 and will be doing a full spread of before pictures with works in progress.
I will be doing the bench to bucket and center console swap out as well.
Well short and sweet hello
Moose
Moose
The car is a 68 cutlass s post. Bench seat and auto on the tree. 12 bolt one wheel wonder.
Motor in it at this time is a 65. 425 I didn't check the carb so not sure if its 2 or 4 barrel the owner has a 68 350 motor to go with the car as well.
Can any one decipher this for me it's the body tag info. Top to bottom and left to right:
04D
ST 68-33677 LAN361194 BODY
TR 950 K-2 PAINT
I will try and find the build sheet once I get the car. I know it's generally between frame and gas tank.
04D
TR 950 K-2 PAINT
Welcome,
Built 4th week of April 68
Lansing Plant
Black bench seat
Ocean Turquoise with a Black vinyl top
You won't find a build sheet under the tank or anywhere in the car. You may find a Fisher Body card under the back seat
Lansing Plant
Black bench seat
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
Thank you for the information, could you also do the VIN if I provide you it?
I checked the door jams for information on tire size and such and the one on the drivers side is almost completely faded out to where you can't see a thing :/
The VIN won't really tell you anything more. The car won't have a build sheet because its a Lansing car. The other BOP plants were more likely to leave paperwork in the car. Lansing built cars did not.
